Dear LAMMPS users:
I am running into a problem while simulating a NEMD shear using fix/deform with nvt/sllod. Currently using lammps 26Jan 2017 (what’s available on the cluster)
My system contains FENE polymer chains with LJ solvent particles and small planar rigid particles. During the shear process, I get the following lost atom error in the thermo output:
Step Temp c_usual E_pair TotEng Press Pxz
3247 0.79962262 0.76663426 -8.1017349 -0.78377635 -0.25579495 -0.42698142
3248 0.80109391 0.76801819 -8.1028895 -0.78260881 -0.25778403 -0.42926876
3249 0.80213932 0.76894776 -8.1038341 -0.78138719 -0.25546524 -0.49882361
ERROR: Lost atoms: original 28900 current 28899 (…/thermo.cpp:427)
Upon inspection, I realized that it was the rigid bodies that were being lost right when the flip happens. Based on suggestions from the lammps doc and the mailing list, I applied the nvt/sllod to the solvent+polymer chains with fix/deform for all particles (remap v).
Whats strange is that this problem happens in some configurations and not others at the same number of rigid bodies (thereby leading to repetition issues). Also, this error takes place at different time steps irrespective of the number of rigid bodies for different configurations. I suspect some rigid bodies at the edge or corner are not remaped during the flip. However, all the initial configurations are most likely fine as all of them equilibrates well for 26 million steps (LJ units) and had other tests performed on them.
I tried reducing the timestep, increasing communication cutoff, using a bigger system and lowering the shear strain rate but the problem still persists.
I’ve tried debugging for weeks; so I decided to post here. Any suggestions on how to address this issue of “lost atoms” is highly appreciated.
Thank you,
Shoumik
Stony Brook University, NY
