Hi Dear Lammps users
I am using pair style hybrid with tersoff, eam and morse.
My commands seems correct but when the Lammps read the fourth line I got this error:
Incorrect args for pair coefficients (…/pair_morse.cpp:201)
My pair_style and pair_coeff commands are shown below.
pair_style hybrid eam/alloy tersoff morse 2.5 morse 2.5
pair_coeff * * eam/alloy ${PotDir}Cu_Sheng.eam.alloy Cu NULL NULL
pair_coeff * * tersoff ${PotDir}SiC.tersoff NULL C Si
pair_coeff 3 1 morse 1 0.4824 1.322 2.92
pair_coeff 2 1 morse 2 0.469 1.738 2.246
What is wrong with my commands?
Any help is appreciated very much
RJ Ford
*always* mention the exact version of LAMMPS that you are using and
what platform you are running on, when discussing error message and
inputs that don't work as expected.
this error:
Incorrect args for pair coefficients (../pair_morse.cpp:201)
there is no need to list morse twice here.
BTW: you may want to consider using the environment variable
LAMMPS_POTENTIALS to look up potential files and a dedicated
directory.
don't know. the syntax seems correct for the current version of LAMMPS.
Hi
Thank you very much for your quick reply.
I am using Lammps 23 Sep 13 on Linux Ubuntu 10.04.4 LTS with 8 core Xeon
computer.
Removing one of the morse potential and changing to these commands doesn't
help solving the problem:
pair_coeff * * eam/alloy \{PotDir\}Cu\_Sheng\.eam\.alloy Cu NULL NULL
pair\_coeff \* \* tersoff {PotDir}SiC.tersoff NULL C Si
pair_coeff 3 1 morse 0.4824 1.322 2.92 2.5
pair_coeff 2 1 morse 0.469 1.738 2.246 2.5
Sincerely you
RJ Ford
Hi
computer.
please look at the pair_coeff documentation:
I and J can be specified in one of two ways. Explicit numeric values
can be used for each, as in the 1st example above. ** I <= J is
required**. LAMMPS sets the coefficients for the symmetric J,I
interaction to the same values.
