Dear LAMMPS users,
I tested the “reset_ids” command by a simple SPC/E water model.
The simulation first runs 5000 steps, and then resets the ids, but it always reports the error:
Bond atoms # # missing
However if I comment “reset_ids” command, everything is fine.
And reset_ids is not used before a pair_style is defined.
The main script is system.in. All the files for the simulation are in the attachment.
Best wishes,
Wei
system.in (604 Bytes)
system.data (412 KB)
H2O.txt (550 Bytes)
system.in.charges (45.9 KB)
system.in.settings (109 KB)
system.in.init (294 Bytes)
