I recently compiled the newest version of the LAMMPS software (28Oct12). It works fine with every system that I have tried so far except the attached data file and input file. It generates the following error message. However, these data and input files work fine with the older versions of LAMMPS. I wonder if you could elaborate on that.
Err Msgs:
LAMMPS (28 Oct 2012)
Scanning data file …
2 = max bonds/atom
6 = max angles/atom
6 = max dihedrals/atom
Reading data file …
orthogonal box = (-29.9385 -29.9365 -29.9345) to (29.9385 29.9365 29.9345)
5100 atoms
4500 bonds
6600 angles
[maginnfe:10432] *** Process received signal ***
[maginnfe:10432] Signal: Segmentation fault (11)
[maginnfe:10432] Signal code: Address not mapped (1)
[maginnfe:10432] Failing at address: (nil)
[maginnfe:10432] [ 0] /lib64/libpthread.so.0 [0x3b13c0ebe0]
[maginnfe:10432] [ 1] ./lmp_linux(_ZN9LAMMPS_NS4Atom14data_dihedralsEiPc+0xe1) [0x488801]
[maginnfe:10432] [ 2] ./lmp_linux(_ZN9LAMMPS_NS8ReadData7commandEiPPc+0x105a) [0x84e8ba]
[maginnfe:10432] [ 3] ./lmp_linux(_ZN9LAMMPS_NS5Input15execute_commandEv+0x11e8) [0x62e6a8]
[maginnfe:10432] [ 4] ./lmp_linux(_ZN9LAMMPS_NS5Input4fileEv+0x2e7) [0x62c217]
[maginnfe:10432] [ 5] ./lmp_linux(main+0x94) [0x644514]
[maginnfe:10432] [ 6] /lib64/libc.so.6(__libc_start_main+0xf4) [0x3b12c1d994]
[maginnfe:10432] [ 7] ./lmp_linux(_ZNSt8ios_base4InitD1Ev+0x41) [0x4735b9]
[maginnfe:10432] *** End of error message ***
Segmentation fault
I don’t know why every other example works fine except this one. Also, this one works fine with older lammps!!!
Tf2N-N1114-Mixture-300.data (944 KB)
in.classI (1.67 KB)
