Dear Lammps users and developers,
the latest stable version as well as the GitHub version can be now alternatively build with cmake. However I have problems compiling the USER-OMP package.
Everything works fine with 16Mar18 version, which uses only the old make. But I can't compile USER-OMP in 22Aug18 version.
What I do using cmake:
mkdir build; cd build; cmake -D PKG_USER-OMP=yes ../cmake; make -j8
Looks fine, the -fopenmp flag is automatically added, but the test script fails, saying there is no USER-OMP
time OMP_NUM_THREADS=2 mpirun -n 4 ./lmp -sf omp -pk omp 2 -in in.test
LAMMPS (22 Aug 2018)
using 2 OpenMP thread(s) per MPI task
ERROR: Using suffix omp without USER-OMP package installed (src/lammps.cpp:681)
Last command: (unknown)
Alternatively I tried the old make:
cd ../src;make yes-user-omp
Installing package user-omp
Looks good, but checking by make package-status gives a lot of errors
Installed YES: package USER-OMP
src/angle_charmm_omp.cpp does not exist
src/angle_class2_omp.cpp does not exist
src/angle_cosine_delta_omp.cpp does not exist
src/angle_cosine_omp.cpp does not exist
src/angle_cosine_periodic_omp.cpp does not exist
src/angle_cosine_shift_exp_omp.cpp does not exist
src/angle_cosine_shift_omp.cpp does not exist
src/angle_cosine_squared_omp.cpp does not exist
src/angle_dipole_omp.cpp does not exist
src/angle_fourier_omp.cpp does not exist
src/angle_fourier_simple_omp.cpp does not exist
src/angle_harmonic_omp.cpp does not exist
src/angle_quartic_omp.cpp does not exist
src/angle_sdk_omp.cpp does not exist
src/angle_table_omp.cpp does not exist
src/bond_class2_omp.cpp does not exist
src/bond_fene_expand_omp.cpp does not exist
src/bond_fene_omp.cpp does not exist
I think the problem is that these files, which were before directly in src/, are now located in src/USER-OMP/ directory, but make does not find them. Not sure about cmake though.
Building is surprisingly without problems:
make -j8 ubuntu_simple
where I have manually added -fopenmp in Makefile.ubuntu_simple
But test script fails as well, although in a different manner:
using multi-threaded neighbor list subroutines
Reading data file ...
orthogonal box = (-62.663 -61.6246 -62.0203) to (62.663 61.6246 62.0203)
2 by 1 by 2 MPI processor grid
reading atoms ...
120833 atoms
reading velocities ...
120833 velocities
Changing box ...
ERROR: Unknown pair style eam/fs (../force.cpp:262)
Last command: pair_style eam/fs
