I want to use the reaxff force field in lamps to perform molecular dynamics simulations. My system is relatively simple, which is the reaction of toluene, oxygen and carbon monoxide at high temperatures. However, this reaction is very slow when using the CPU to perform parallel calculations, so I thought about using kokkos and cuda for gpu acceleration. My in file is as follows:
units real ##fs Å
atom_style full
read_data 10_0_11_0_11.data
pair_style reaxff NULL safezone 4.0 mincap 100
pair_coeff * * CHO.ff C H O
fix 1 all qeq/reaxff 1 0.0 10.0 1.0e-6 reaxff
neighbor 2.0 bin
minimize 1e-10 1e-10 10000 10000
fix 11 all nve
fix 22 all temp/berendsen 2500 2500 500
fix 5 all reaxff/species 1 100 100 species.out element C H O
fix 6 all reaxff/bonds 1000 bonds.reaxc
timestep 0.10
thermo_style custom step time temp etotal pe ke density press
thermo 100
dump 2 all custom 500 mydump-nvt.lammpstrj id mol type x y z q
dump xtcout all xtc 100 myxtc-nvt.xtc
run 100000000
restart 1000000 restart.equil
write_restart restart_.equil1
The command to use is:
lmp -in in.NVT -k on g 1 -sf kk -pk kokkos neigh half newton on
At this time, the calculation can still run normally, but it prompts me that I cannot use kokkos for acceleration due to fix-related issues. The specific error reported is as follows:
WARNING: Fix with atom-based arrays not compatible with sending data in Kokkos communication, switching to classic exchange/border communication (src/KOKKOS/comm_kokkos.cpp:666)
WARNING: Fix with atom-based arrays not compatible with Kokkos sorting on device, switching to classic host sorting (src/KOKKOS/atom_kokkos.cpp:178)
This gives me a headache, because these fix commands are the core steps of my calculations. I hope you can give me some suggestions to help me use kokkos normally.
