Dear lammps user
I have been working with PDLAMMPS since 9 month ago and ran into several problems.
I describe one of problems below.
I want to simulate a system with PDLAMMPS using NPT ensemble under external pressure and got #IND for all desired output data after 200 steps. I will really appreciate if anyone could help me to solve this problem.
Here are my input scripts and output results:
small Peridynamic cube under external pressure S0
clear
units si
atom_style peri
atom_modify map array
neighbor 1.2e-8 bin
#------------- simulation box --------------
lattice sc 0.28e-8
region target block 0 0.5e-7 0 0.5e-7 0 0.5e-7 units box
create_box 1 target
create_atoms 1 region target
#------------- PD Potentials --------------
pair_style peri/lps
pair_coeff * * 3.14e9 1.2e9 0.9e-8 0.005 0.25
set group all density 1200
set group all volume 2.1982-26
velocity all create 0.1 4928459 mom yes rot yes dist uniform
#------------- NPT run under external pressure --------------
thermo 100
thermo_style custom step temp press vol lx ly lz
fix 1 all npt temp 0.1 0.1 100 iso -2.97e12 -2.97e12 1000
dump 2 all atom 10 NPT.xyz
timestep 1.0e-8
run 5000
output results
Step Temp Press Volume Lx Ly Lz
0 0.1 64.40458 1.25e-022 5e-008 5e-008 5e-008
100 0.099999995 64.404572 1.2500001e-022 5.0000001e-008 5.0000001e-008 5.0000001e-008
200 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
300 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
400 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
500 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
600 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
700 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
800 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
900 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
1000 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
1100 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
1200 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
1300 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
1400 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
1500 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
1600 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
1700 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
1800 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
1900 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
2000 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
2100 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
2200 -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND -1.#IND
Regards
Faraz M. Honarvar
PhD candidate of Polymer Engineering
Polymer Engineering Faculty
Sahand University Of Technology (SUT)
Tabriz- IRAN
TEL: (+98) 9123194229
NPT run in PDLAMMPS.in (985 Bytes)
output results.txt (2.04 KB)
