I am trying to compile LAMMPS with the Kokkos package on GPU to be able to run simulations employing a MACE ML trained model. From the MACE documentation (MACE in LAMMPS — mace 0.1.0 documentation) and from crosschecking with the documentation of LAMMPS I tried to compile LAMMPS using two presets “most” and “kokkos-cuda”. the command “cmake -C …/cmake/presets/most.cmake -C …/cmake/presets/kokkos-cuda.cmake …/cmake” works find and prepares the compilation, but after “cmake --build .” the compilation always crashed in the very first steps when building the voronoi package:
– extracting… done
[ 1%] No update step for ‘voro_build’
[ 1%] Performing patch step for ‘voro_build’
patching file src/Makefile
[ 1%] No configure step for ‘voro_build’
[ 1%] Performing build step for ‘voro_build’
/tmp/tmpxft_00005216_00000000-45_cell.cpp1.ii(1): error: this declaration has no storage class or type specifier
/tmp/tmpxft_00005216_00000000-45_cell.cpp1.ii(1): error: expected a “;”
2 errors detected in the compilation of “cell.cc”.
make[4]: *** [Makefile:19: depend] Error 1
make[3]: *** [Makefile:14: all] Error 2
gmake[2]: *** [CMakeFiles/voro_build.dir/build.make:86: voro_build-prefix/src/voro_build-stamp/voro_build-build] Error 2
gmake[1]: *** [CMakeFiles/Makefile2:507: CMakeFiles/voro_build.dir/all] Error 2
gmake: *** [Makefile:136: all] Error 2
I manually removed the Voronoi package from the “most” preset whih led to:
[ 0%] Building CXX object lib/kokkos/simd/src/CMakeFiles/kokkossimd.dir/Kokkos_SIMD_dummy.cpp.o
[ 0%] Linking CXX static library libkokkossimd.a
[ 0%] Built target kokkossimd
[ 0%] Building CXX object CMakeFiles/lepton.dir/home/jabr/md-software/lammps-29Aug2024/lib/lepton/src/CompiledExpression.cpp.o
/usr/include/c++/11/bits/std_function.h:435:145: error: parameter packs not expanded with ‘…’:
435 | function(_Functor&& __f)
/usr/include/c++/11/bits/std_function.h:435:145: note: ‘_ArgTypes’
/usr/include/c++/11/bits/std_function.h:530:146: error: parameter packs not expanded with ‘…’:
530 | operator=(_Functor&& __f)
/usr/include/c++/11/bits/std_function.h:530:146: note: ‘_ArgTypes’
gmake[2]: *** [CMakeFiles/lepton.dir/build.make:76: CMakeFiles/lepton.dir/home/jabr/md-software/lammps-29Aug2024/lib/lepton/src/CompiledExpression.cpp.o] Error 1
gmake[1]: *** [CMakeFiles/Makefile2:503: CMakeFiles/lepton.dir/all] Error 2
upon compiling.
I hope that maybe someone can provide some tips on how to resolve this.
For completeness, below I show the message after “cmake -C […] …/cmake”:
loading initial cache file …/cmake/presets/most.cmake
loading initial cache file …/cmake/presets/kokkos-cuda.cmake
CMake Deprecation Warning at CMakeLists.txt:18 (cmake_policy):
The OLD behavior for policy CMP0109 will be removed from a future version
of CMake.
The cmake-policies(7) manual explains that the OLD behaviors of all
policies are deprecated and that a policy should be set to OLD only under
specific short-term circumstances. Projects should be ported to the NEW
behavior and not rely on setting a policy to OLD.
- The CXX compiler identification is GNU 11.4.0
– Detecting CXX compiler ABI info
– Detecting CXX compiler ABI info - done
– Check for working CXX compiler: /home/jabr/md-software/lammps-29Aug2024/lib/kokkos/bin/nvcc_wrapper - skipped
– Detecting CXX compile features
– Detecting CXX compile features - done
– Found Git: /usr/bin/git (found version “2.34.1”)
– Running check for auto-generated files from make-based build system
– Found MPI_CXX: /usr/lib/x86_64-linux-gnu/openmpi/lib/libmpi_cxx.so (found version “3.1”)
– Found MPI: TRUE (found version “3.1”)
– Looking for C++ include omp.h
– Looking for C++ include omp.h - found
– Found OpenMP_CXX: -fopenmp (found version “4.5”)
– Found OpenMP: TRUE (found version “4.5”) found components: CXX
– The C compiler identification is GNU 11.4.0
– Detecting C compiler ABI info
– Detecting C compiler ABI info - done
– Check for working C compiler: /usr/bin/cc - skipped
– Detecting C compile features
– Detecting C compile features - done
– Looking for sgemm_
– Looking for sgemm_ - not found
– Performing Test CMAKE_HAVE_LIBC_PTHREAD
– Performing Test CMAKE_HAVE_LIBC_PTHREAD - Success
– Found Threads: TRUE
– Looking for sgemm_ - found
– Found BLAS: /usr/lib/x86_64-linux-gnu/libopenblas.so
– Looking for cheev_
– Looking for cheev_ - found
– Found LAPACK: /usr/lib/x86_64-linux-gnu/libopenblas.so;-lm;-ldl
– Found GZIP: /usr/bin/gzip
– Could NOT find FFMPEG (missing: FFMPEG_EXECUTABLE)
– Could NOT find PkgConfig (missing: PKG_CONFIG_EXECUTABLE)
– Could NOT find Eigen3 (missing: Eigen3_DIR)
– Eigen3 download requested - we will build our own
– Found ZLIB: /usr/lib/x86_64-linux-gnu/libz.so (found version “1.2.11”)
– Looking for C++ include cmath
– Looking for C++ include cmath - found
– Downloading external potential C_10_10.mesocnt from https://download.lammps.org/potentials
– [download 0% complete]
– [download 100% complete]
– KOKKOS: Enabling CUDA LAMBDA function support
– Setting default Kokkos CXX standard to 17
– Kokkos version: 4.3.1
– The project name is: Kokkos
– Using internal gtest for testing
– Compiler Version: 11.5.119
– Using -std=c++17 for C++17 standard as feature
– Built-in Execution Spaces:
– Device Parallel: Kokkos::Cuda
– Host Parallel: NoTypeDefined
– Host Serial: SERIAL
– Architectures:
– PASCAL60
– Found CUDAToolkit: /usr/include (found version “11.5.119”)
– Found TPLCUDA: TRUE
– Found TPLLIBDL: /usr/include
– Using internal desul_atomics copy
– Kokkos Backends: SERIAL;CUDA
– Generating style headers…
– Generating package headers…
– Generating lmpinstalledpkgs.h…
– Looking for a Fortran compiler
– Looking for a Fortran compiler - /usr/bin/f95
– The Fortran compiler identification is GNU 11.4.0
– Detecting Fortran compiler ABI info
– Detecting Fortran compiler ABI info - done
– Check for working Fortran compiler: /usr/bin/f95 - skipped
– Could NOT find FFTW3 (missing: FFTW3_LIBRARY FFTW3_INCLUDE_DIR)
– Found Python3: /home/jabr/miniconda3/bin/python3.9 (found version “3.9.12”) found components: Interpreter
– Could NOT find ClangFormat (missing: ClangFormat_EXECUTABLE) (Required is at least version “11.0”)
– The following tools and libraries have been found and configured:
- MPI
- OpenMP
- LAPACK
- BLAS
- ZLIB
- TPLCUDA
- TPLLIBDL
- Threads
- CUDAToolkit
- Python3
– <<< Build configuration >>>
LAMMPS Version: 20240829
Operating System: Linux Ubuntu" 22.04
CMake Version: 3.27.2
Build type: RelWithDebInfo
Install path: /home/jabr/.local
Generator: Unix Makefiles using /usr/bin/gmake
– Enabled packages: AMOEBA;ASPHERE;BOCS;BODY;BPM;BROWNIAN;CG-DNA;CG-SPICA;CLASS2;COLLOID;COLVARS;COMPRESS;CORESHELL;DIELECTRIC;DIFFRACTION;DIPOLE;DPD-BASIC;DPD-MESO;DPD-REACT;DPD-SMOOTH;DRUDE;EFF;ELECTRODE;EXTRA-COMMAND;EXTRA-COMPUTE;EXTRA-DUMP;EXTRA-FIX;EXTRA-MOLECULE;EXTRA-PAIR;FEP;GRANULAR;INTERLAYER;KOKKOS;KSPACE;LEPTON;MACHDYN;MANYBODY;MC;MEAM;MESONT;MISC;ML-IAP;ML-POD;ML-SNAP;ML-UF3;MOFFF;MOLECULE;OPENMP;OPT;ORIENT;PERI;PHONON;PLUGIN;POEMS;QEQ;REACTION;REAXFF;REPLICA;RIGID;SHOCK;SPH;SPIN;SRD;TALLY;UEF;YAFF
– <<< Compilers and Flags: >>>
– C++ Compiler: /home/jabr/md-software/lammps-29Aug2024/lib/kokkos/bin/nvcc_wrapper
Type: GNU
Version: 11.4.0
C++ Standard: 17
C++ Flags: -O2 -g -DNDEBUG
Defines: LAMMPS_SMALLBIG;LAMMPS_MEMALIGN=64;LAMMPS_OMP_COMPAT=4;LAMMPS_GZIP;FFT_KISS;EIGEN_NO_CUDA;LMP_OPENMP;$<BUILD_INTERFACE:LMP_KOKKOS>;FFT_KOKKOS_CUFFT;LMP_PLUGIN
Options: -Xcudafe;–diag_suppress=unrecognized_pragma
– Fortran Compiler: /usr/bin/f95
Type: GNU
Version: 11.4.0
Fortran Flags: -O2 -g -DNDEBUG
– C compiler: /usr/bin/cc
Type: GNU
Version: 11.4.0
C Flags: -O2 -g -DNDEBUG
– <<< Linker flags: >>>
– Executable name: lmp
– Static library flags:
– <<< MPI flags >>>
– MPI_defines: MPICH_SKIP_MPICXX;OMPI_SKIP_MPICXX;_MPICC_H
– MPI includes: /usr/lib/x86_64-linux-gnu/openmpi/include;/usr/lib/x86_64-linux-gnu/openmpi/include/openmpi
– MPI libraries: /usr/lib/x86_64-linux-gnu/openmpi/lib/libmpi_cxx.so;/usr/lib/x86_64-linux-gnu/openmpi/lib/libmpi.so;
– Kokkos Devices: CUDA;CUDA_LAMBDA;SERIAL
– Kokkos Architecture: PASCAL60
– <<< FFT settings >>>
– Primary FFT lib: KISS
– Using double precision FFTs
– Using non-threaded FFTs
– Using builtin distributed FFT algorithms
– Kokkos FFT: CUFFT
– <<< Building Tools >>>
– Configuring done (74.5s)
– Generating done (0.2s)
– Build files have been written to: /home/jabr/md-software/lammps-29Aug2024/build
