This problem is not related to #45328, because it happens on other machine
In my in.file
I write
dump ADIOSDUMP all atom/adios 1000 dump.pb
The log.lammps
out
fix extra all print 1000 "${str},${tm}" file temperature.log screen no
fix NVEFIX all nve
run 100000
Generated 0 of 0 mixed pair_coeff terms from geometric mixing rule
Per MPI rank memory allocation (min/avg/max) = 3.882 | 3.905 | 3.932 Mbytes
Step Temp E_pair E_mol TotEng Press
1 0.75 0 0 1.1249989 0.017310929
10000 0.8607381 -0.16610778 0 1.1249981 0.017763544
20000 0.87661253 -0.18991941 0 1.1249981 0.017943719
30000 0.88269194 -0.1990385 0 1.1249981 0.017942047
40000 0.88435167 -0.20152811 0 1.1249981 0.0179933
50000 0.88575 -0.2036257 0 1.124998 0.017979413
60000 0.88605093 -0.20407703 0 1.124998 0.017980362
70000 0.88624206 -0.2043638 0 1.124998 0.017974951
80000 0.886276 -0.20441486 0 1.1249978 0.017998695
90000 0.88605867 -0.20408897 0 1.1249977 0.018039604
100000 0.88632049 -0.20448177 0 1.1249976 0.018025306
100001 0.88631973 -0.20448063 0 1.1249976 0.018025409
Loop time of 84.0754 on 128 procs for 100000 steps with 1000188 atoms
Performance: 513824.597 tau/day, 1189.409 timesteps/s
97.9% CPU use with 128 MPI tasks x 1 OpenMP threads
MPI task timing breakdown:
Section | min time | avg time | max time |%varavg| %total
Pair | 20.529 | 21.338 | 25.308 | 9.6 | 25.38
Neigh | 8.6221 | 8.8277 | 9.1821 | 2.9 | 10.50
Comm | 28.764 | 31.257 | 33.564 | 14.8 | 37.18
Output | 5.8702 | 5.8867 | 5.9245 | 0.4 | 7.00
Modify | 6.8585 | 7.0174 | 9.8193 | 10.3 | 8.35
Other | | 9.748 | | | 11.59
Nlocal: 7813.97 ave 8072 max 7557 min
Histogram: 2 5 14 22 24 23 10 17 10 1
Nghost: 2158.59 ave 2286 max 2049 min
Histogram: 8 6 11 24 33 14 11 13 4 4
Neighs: 9464.66 ave 10185 max 8797 min
Histogram: 3 7 11 26 20 26 17 11 6 1
Total # of neighbors = 1211477
Ave neighs/atom = 1.2112493
Neighbor list builds = 3498
Dangerous builds = 0
And then it happens on the screen
terminate called after throwing an instance of 'std::invalid_argument'
what(): [Mon Nov 7 04:00:13 2022] [ADIOS2 EXCEPTION] <Core> <ADIOS> <DeclareIO> : IO atom declared twice
My ADIOS2 build configuration
Pastebin
LAMMPS build configuration (LAMMPS (23 Jun 2022 - Update 2))
Pastebin
OS - SUSE Linux Enterprise Server 12 SP3
Platform - Linux head-epyc 4.4.73-5-default #1 SMP Tue Jul 4 15:33:39 UTC 2017 (b7ce4e4) x86_64
Cmake version 3.18.0
