lammps version:LAMMPS 64-bit 29Aug2024-MSMPI
After outputting the DATA file using the “write_data” command at the end of the input file and opening the data file with VMD, it was observed that the model spreads outward and some particles extend beyond the box (Fig. a). This may be due to LAMMPS outputting the actual trajectory of the particles. The “dump Dump1 all dcd 10000 prod.dcd; dump_modify Dump1 unwrap no” command was subsequently used to output the periodic particle trajectory file, which was then loaded into VMD. It was found that some bonds lengths were too long (Fig. b), which may be attributed to the periodic boundary conditions, which may cause this issue. Guidance on how to display the model and bonds lengths normally (e.g. Fig. c) would be appreciated.
I tried using “mol bondsrecalc all” in VMD; however, this did not resolve the issue.
