Dear LAMMPS users and developers,
I am having problems with the command “compute com” in a simulation of a lj system. I just want to calculate the translational and non-translational contributions to the total kinetic energy of all the atoms in the box.
When I do this modifying the LAMMPS code (in FixHeat::end_of_step(), for test purposes), I get a sensible value as compared to the total kinetic energy.
However, when I calculate the com velocity using “compute all com” and subsequently square and multiply it by the total mass over two, I get a value that is several orders of magnitudes off (117355.16).
I saw in the documentation of temp “compute com” that the vector is given in distance units. I am working with a lj system, that’s why several conversion factors are unity. Division by the timestep (0.001) would also not account for that.
My question is now: Why are the velocities calculated with group->vcm(0,group->mass(0), all_vcm) and compute all com not identical (group-id 0 is “all”)?
My apologies for posting such a simple question, but I got stuck.
Best wishes
Peter
Here is the (quick & dirty) piece of code I added to “fix_heat” (with which I am experimenting around) to create the additional output for validation.
double all_masstotal = group->mass(0);
double all_ke = group->ke(0)*force->ftm2v;
double all_vcm[3];
group->vcm(0,all_masstotal,all_vcm);
double all_vcm2 = (all_vcm[0]*all_vcm[0] + all_vcm[1]*all_vcm[1] + all_vcm[2]*all_vcm[2]);
double all_ke_trans = 0.5all_masstotalall_vcm2 * force->ftm2v;
double all_ke_ntrans = all_ke - all_ke_trans;
if (update->ntimestep % 200 == 0) {
printf("(FIXHEAT: all_vcm^2 = %lf, \t all_vcm = (%lf, %lf, %lf))\n",all_vcm2, all_vcm[0], all_vcm[1], all_vcm[2]);
Here is the console output (please ignore the first part in which the crystal is melted):
pw359@…4757…:~/fixheat/lj/test/300_dt0.001$ ~/apps/lammps-25Nov13_test/src/lmp_openmpi -in lj.lmp
LAMMPS (25 Nov 2013)
Lattice spacing in x,y,z = 1.6796 1.6796 1.6796
Created orthogonal box = (0 0 0) to (10.0776 10.0776 20.1552)
Created 1728 atoms
Setting up run …
Memory usage per processor = 2.76758 Mbytes
Step Temp KinEng PotEng TotEng Press
0 3 4.4973958 -6.9999116 -2.5025157 -4.2703406
200 1.6845059 2.5252967 -4.9835801 -2.4582834 5.2630082
400 1.6907258 2.534621 -4.9418267 -2.4072057 5.4643114
600 1.6763134 2.513015 -4.9063603 -2.3933453 5.626113
800 1.7144289 2.5701551 -4.9305688 -2.3604136 5.5360477
1000 1.7305419 2.5943106 -4.940948 -2.3466374 5.4973514
Loop time of 4.85131 on 1 procs for 1000 steps with 1728 atoms
Pair time () = 4.22079 (87.0031)
Neigh time () = 0.464731 (9.57951)
Comm time () = 0.0492308 (1.01479)
Outpt time () = 0.000480175 (0.00989784)
Other time (%) = 0.116078 (2.39272)
Nlocal: 1728 ave 1728 max 1728 min
Histogram: 1 0 0 0 0 0 0 0 0 0
Nghost: 6791 ave 6791 max 6791 min
Neighs: 242270 ave 242270 max 242270 min
Total # of neighbors = 242270
Ave neighs/atom = 140.203
Neighbor list builds = 50
Dangerous builds = 0
WARNING: New thermo_style command, previous thermo_modify settings will be lost (…/output.cpp:665)
Setting up run …
Memory usage per processor = 2.77502 Mbytes
Step KinEng ke_all1 ke_all_t vcm2_all vcm_all[ vcm_all[ vcm_all[
1000 2.5943106 2.5943106 117355.16 135.82773 4.5944417 4.6220746 9.6620529
(FIXHEAT: all_vcm^2 = 0.001971, all_vcm = (-0.043345, 0.001141, 0.009516))
1200 2.5751388 2.5751388 117320 135.78704 4.5857728 4.6223029 9.663956
1400 2.5802637 2.5802637 117284.98 135.74651 4.5771039 4.6225312 9.6658591
1600 2.5686618 2.5686618 117250.1 135.70613 4.568435 4.6227595 9.6677623
Relevant parts of the Input file (see full file attached lj.lmp)
fix NVE all nve
compute ke all ke/atom
1) Calculate total kinetic energy
compute ke_all1 all ke
2) Alternative way to calculate total kinetic energy (for validation)
compute ke_all2 all reduce sum c_ke
3) Alternative way to calculate the total kinetic energy (validation for 4))
variable ke3 atom mass*(vxvx+vyvy+vz*vz)/2.
compute ke_all3 all reduce sum v_ke3
4) Calcualte translational kinetic energy of entire box (ke_all_t)
compute vcm_all all com
compute m all property/atom mass
compute m_all all reduce sum c_m
variable vcm2_all equal c_vcm_all[1]*c_vcm_all[1]+c_vcm_all[2]*c_vcm_all[2]+c_vcm_all[3]c_vcm_all[3]
variable ke_all_t equal c_m_allv_vcm2_all/2.
variable ke_all_nt equal c_ke_all1-v_ke_all_t
thermo 200
thermo_style custom step ke c_ke_all1 v_ke_all_t v_vcm2_all c_vcm_all[1] c_vcm_all[2] c_vcm_all[3]
thermo_modify flush yes
run ${Nprod}
lj.lmp (2.96 KB)
