I have some problems with invoking computes in my own code when using the LAMMPS library. After reading the input script, I define a compute command as follows:
lmp -> input -> one (“compute per_atom_stress all stress/atom\n”);
and after running my simulation every 5 timesteps, I invoke the compute using the following command
stressList = (double**) lammps_extract_compute (lmp, (char*) “per_atom_stress”, 1, 2);
but I get the following error:
ERROR: Per-atom virial was not tallied on needed timestep (compute_stress_atom.cpp:98)
I went to LAMMPS documentation and found the following explanation:
But this simply does make no sense since I am calculating a per-atom quantity and not a global variable for which thermo is used. Nevertheless, I added the command “thermo 5” and even “thermo 1” to my scrip but the problem was unresolved. I asked one of my friends, and he independently reproduced the same error with his own code:
#include “mpi.h”
#include “library.h”
#include “lammps.h”
#include “atom.h”
#include “input.h”
#include “memory.h”
using namespace std;
using namespace LAMMPS_NS;
int main(int argc, char** argv)
int procs, me;
MPI_Init(&argc, &argv);
MPI_Comm_size(MPI_COMM_WORLD, &procs);
MPI_Comm_rank(MPI_COMM_WORLD, &me);
LAMMPS* lmp = new LAMMPS(argc, argv, MPI_COMM_WORLD);
char command[256];
lmp->input->one(“units lj\n”);
lmp->input->one(“atom_style atomic\n”);
lmp->input->one(“lattice fcc 0.8442\n”);
lmp->input->one(“region box block 0 10 0 10 0 10\n”);
lmp->input->one(“create_box 1 box\n”);
lmp->input->one(“create_atoms 1 box\n”);
lmp->input->one(“mass 1 1.0\n”);
lmp->input->one(“velocity all create 3.0 87287\n”);
lmp->input->one(“pair_style lj/cut 2.5\n”);
lmp->input->one(“pair_coeff 1 1 1.0 1.0 2.5\n”);
lmp->input->one(“neighbor 0.5 bin\n”);
lmp->input->one(“neigh_modify every 1 delay 0 check yes\n”);
lmp->input->one(“thermo 1\n”);
lmp->input->one(“fix 1 all nve\n”);
lmp->input->one(“compute 1 all stress/atom\n”);
lmp->input->one(“run 250\n”);
double** stressList = (double**) lammps_extract_compute (lmp, (char*) “1”, 1, 2);
delete lmp;
MPI_Finalize();
return 0;
My own code is too big and has a lot of unrelated stuff, so including it will be more of a burden than a help.
Regards
Amir
