I think we need to make some decisions about how to use the task_label only uses the name field from the job.
I think the name of a job is not a super well-protected field since many workflows use it for bookkeeping.
We should make this a bit more formal and make sure that the task label is only going to be things that is interoperable with atomate1 tasks databases.
I believe task_label was also not particularly well-defined in atomate v1. I’ve always been of the opinion that relying on task label as reliable metadata was dangerous, since it’s typically not encoded in the launch directory (correct?) so can get lost on re-parse.
I don’t know about the validation builder, but I can say that 1) I have frequently used the task_label to add user-defined metadata to a job name and 2) it is not very robust!
I think it is important to have a human-interpretable name for task documents, but enforcing a rigid schema would be valuable
So I think atomate 2 should have a task_label populated by the workflow in some way that is more protected than the name field which currently gets modified a bit by the more complex workflows:
