I want to simulate a protein using charmm force field.
I have a pdb file for it. As it is not a known structure, I have built it from MODELLER software. Then I need to create a data file for the charmm force field. Unfortunately the modeller has not given a regular file (the columns 10 and 11 interruption). To build a data file for lammps I need to use this command as you know (perl charmm2lammps.pl all27_prot_lipid configuration_autopsf). But as I mentioned I don’t have a good pdb file so that VMD does not give a psf file (although It is readable via it)
Is there any alternative way?
I have attached the pdb file of the protein.
TvLDH.B99990005.pdb (526.1 KB)
