I am new to ATAT. When generating a Pt-Ni phase diagram, I ran into a problem that the composition-temperature phase boundaries of single-phase (Pt3Ni and PtNi) are incomplete.
Here is the description of the problem.
(1) I used my own cluster expansions (lat.in, clusters.out, eci.out, and gs_str.out)
Inside gs_str.out, pure Pt, ordered Pt3Ni, ordered PtNi, ordered PtNi3, and pure Ni are listed, which correspond to gs=0, gs=1, gs=2, gs=3, and gs=4, respectively. The disordered phase (Pt-Ni solid solution) is gs=-1, according to the manual of ATAT.
(2) To build the phase diagram in the Pt-rich region, I tried to compute the two-phase equilibria.
For example, for the two-phase equilibrium between phase 1 (Pt3Ni) and phase 2 (PtNi),
(2-i) I ran the following phb command:
phb -gs1=1 -gs2=2 -dT=10 -dmu=0.001 -er=20 -ltep=1e-3 -o=phb-gs1=1-gs2=2-test1.out -k=8.617e-5 -dx=1e-3
This command automatically finished at T=540 and mu=-0.0385916, which meant that the "end" of two-phase equilibrium has been reached, and a third phase appears (disordered phase -1).
(2-ii), in order to compute two new two-phase equilibria (phase 1 and phase -1, & phase 2 and phase -1), I separately ran the following two commands:
phb -T=540 -mu=-0.0385916 -gs1=1 -gs2=-1 -dT=10 -dmu=0.001 -er=20 -ltep=1e-3 -o=phb-gs1=1-gs2=-1-test1-sT=540.out -k=8.617e-5 -dx=1e-3
phb -T=540 -mu=-0.0385916 -gs1=-1 -gs2=2 -dT=10 -dmu=0.001 -er=20 -ltep=1e-3 -o=phb-gs1=-1-gs2=2-test1-sT=540.out -k=8.617e-5 -dx=1e-3
Unfortunately, the two commands in step of (2-ii) did complete the phase diagram. The problems I have are:
(A) the phb output of the calculations for the equilibrium between the ordered phase 1 (Pt3Ni) and phase disordered -1 (solid solution) stopped at Pt%=57% & T=560 K, and resembled the results for the equilibrium between the phase 2 (PtNi) and phase -1, which leads to a problem that the left boundary for the region of single-phase Pt3Ni is missing.
(B) Moreover, the phb command to compute the equilibrium between ordered phase 2 (PtNi) and disordered phase -1 finished at Pt%=58% and T=550K so that I was NOT able to identify the transition temperature for PtNi phase to transit to the disordered solid solution phase, which is usually at Pt%=50%.
(C) the similar problem happened for the composition-temperature phase boundaries between phase 0 (pure Pt) and phase 1 (Pt3Ni), & between phase 2 (PtNi) and phase 3 (PtNi3).
Could you please provide some insightful advice for the calculated incomplete Pt-Ni phase diagram?
Thanks.
Liang
