I understand that the Materials Project database contains structures relaxed using both PBE and r2SCAN functionals. Is there a way to specifically filter and retrieve only structures relaxed with either PBE or r2SCAN through the API? I’d like to distinguish between the two for my analysis.
Nigel
Hi @nigel_hew, the easiest way right now is using the origins
field of the summary documents, which will point you to the “task” (a DFT calculation) which generated a given property:
mp_id_to_task_id = {}
with MPRester() as mpr:
summary_docs = mpr.materials.summary.search(fields = ["material_id", "structure", "origins"])
for doc in summary_docs:
for prop in doc.origins:
if prop.name == "structure":
mp_id_to_task_id[doc.material_id] = {
"task_id": prop.task_id,
"structure": doc.structure,
break
thermo_docs = mpr.materials.thermo.search(fields = ["material_id","entries"])
for doc in thermo_docs:
mp_id = doc.material_id
for entry in doc.entries.values():
if entry.data["task_id"] == mp_id_to_task_id[mp_id]["task_id"]:
mp_id_to_task_id[mp_id]["run_type"] = entry.parameters["run_type"]
break
In this case, a run_type
of GGA
indicates a PBE GGA calculation, GGA_U
indicates a PBE+U calculation, and r2SCAN
indicates an r2SCAN calculation
An alternative is to use the tasks
endpoint to directly locate the task which generated the structure. If you take that approach, it’s worth downloading all the tasks and filtering through the IDs you need:
tasks = mpr.materials.tasks.search(fields=["task_id","run_type","structure","energy"])
