Hello!
I’ve installed atomate and the necessary prereqs on a worker and server where I’ve setup and configured a MongoDB instance. I have the atomate config files for the db and workers set up and have confirmed that my MongoDB port is open and reachable via a telnet query and Pymongo connection via MongoClient.
However, I am getting a Pymongo connection error to localhost (I’ve set the correct host and port for my MongoDB server via the db.json file and my_launchpad.yaml files) when I try to submit a workflow via the following script:
#!/usr/bin/env python3
import numpy as np
from pymatgen import MPRester
from fireworks import LaunchPad
from atomate.vasp.workflows.presets.core import wf_elastic_constant
from atomate.vasp.powerups import add_modify_incar
Get the structure from the Materials Project
with MPRester() as mpr:
struct = mpr.get_structure_by_material_id(‘mp-5229’)
# Create the workflow
workflow = wf_elastic_constant(struct)
# Create the launchpad and add our workflow
launchpad = LaunchPad.auto_load()
launchpad.add_wf(workflow)
The error is as follows:
$ python3 elastic_constant.py
/apps2/python/3.6.8/lib/python3.6/site-packages/pandas/compat/init.py:85: UserWarning: Could not import the lzma module. Your installed Python is incomplete. Attempting to use lzma compression will result in a RuntimeError.
warnings.warn(msg)
warnings.warn(msg)
File “/home/det16103/.local/lib/python3.6/site-packages/fireworks/core/launchpad.py”, line 1537, in get_new_fw_id
‘$inc’: {‘next_fw_id’: quantity}})[‘next_fw_id’]
File “/home/det16103/.local/lib/python3.6/site-packages/pymongo/collection.py”, line 3136, in find_one_and_update
array_filters, session=session, **kwargs)
File “/home/det16103/.local/lib/python3.6/site-packages/pymongo/collection.py”, line 2885, in __find_and_modify
write_concern.acknowledged, _find_and_modify, session)
File “/home/det16103/.local/lib/python3.6/site-packages/pymongo/mongo_client.py”, line 1490, in _retryable_write
with self._tmp_session(session) as s:
File “/apps2/python/3.6.8/lib/python3.6/contextlib.py”, line 81, in enter
return next(self.gen)
File “/home/det16103/.local/lib/python3.6/site-packages/pymongo/mongo_client.py”, line 1823, in _tmp_session
s = self._ensure_session(session)
File “/home/det16103/.local/lib/python3.6/site-packages/pymongo/mongo_client.py”, line 1810, in _ensure_session
return self.__start_session(True, causal_consistency=False)
File “/home/det16103/.local/lib/python3.6/site-packages/pymongo/mongo_client.py”, line 1763, in __start_session
server_session = self._get_server_session()
File “/home/det16103/.local/lib/python3.6/site-packages/pymongo/mongo_client.py”, line 1796, in _get_server_session
return self._topology.get_server_session()
File “/home/det16103/.local/lib/python3.6/site-packages/pymongo/topology.py”, line 485, in get_server_session
None)
File “/home/det16103/.local/lib/python3.6/site-packages/pymongo/topology.py”, line 209, in _select_servers_loop
self._error_message(selector))
pymongo.errors.ServerSelectionTimeoutError: localhost:27017: [Errno 111] Connection refused
During handling of the above exception, another exception occurred:
File “elastic_constant.py”, line 19, in
File “/home/det16103/.local/lib/python3.6/site-packages/fireworks/core/launchpad.py”, line 402, in add_wf
reassign_all=reassign_all)
File “/home/det16103/.local/lib/python3.6/site-packages/fireworks/core/launchpad.py”, line 1575, in _upsert_fws
first_new_id = self.get_new_fw_id(quantity=len(fws))
File “/home/det16103/.local/lib/python3.6/site-packages/fireworks/core/launchpad.py”, line 1540, in get_new_fw_id
“Could not get next FW id! If you have not yet initialized the database,”
ValueError: Could not get next FW id! If you have not yet initialized the database, please do so by performing a database reset (e.g., lpad reset)
Any help in regards to resolving this error is appreciated.
Thanks!
-Dennis
