exactly, I used
python -m pip install -U ovito
print("OVITO Version: %i.%i.i" ovito.version) says it is version 3.5.2
The error occurring:
File “”, line 1, in
ImportError: /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.15’ not found (required by /home/user/.local/lib/python3.8/site-packages/PySide2/QtGui.abi3.so)
File “”, line 1, in
File “/home/user/.local/lib/python3.8/site-packages/shiboken2/files.dir/shibokensupport/feature.py”, line 142, in _import
return original_import(name, *args, **kwargs)
File “/home/user/.local/lib/python3.8/site-packages/ovito/init.py”, line 19, in
from .plugins.PyScript import (version, version_string, gui_mode, headless_mode, Scene, scene, dataset, enable_logging)
File “/home/user/.local/lib/python3.8/site-packages/ovito/plugins/init.py”, line 12, in
import PySide2.QtCore
ImportError: /usr/lib/x86_64-linux-gnu/libQt5Core.so.5: version `Qt_5.15’ not found (required by /home/user/.local/lib/python3.8/site-packages/PySide2/QtCore.abi3.so)
File “”, line 1, in
File “”, line 1, in
File “”, line 1, in
NameError: name ‘ovito’ is not defined
import PySide2.QtGui did not work and seems to produce the same result:
File “”, line 1, in
File “”, line 1, in
File “”, line 1, in
File “”, line 1, in
