I’m using the very helpfully fast ovito RDF calculations via the python interface for the first time, but I’m interested in something beyond just total and all the A-B pair partials. There are two things I want, and one is straightforward, but the other I’m just not sure how to do efficiently. I was hoping someone here could suggest documentation to look at or a specific approach I could try.
I want the A-* RDF, i.e. properly weighted sum of \sum_i w_i \mathrm{rdf}(A, B_i). I suppose the weights would just be the number fraction of B_i, x(B_i), right? If so, how can I get those? Is there a pipeline modifier that would return that info?
I sometimes want both total and various A-B partials. I can presumably attach two
CoordinationAnalysisModifiers, one withpartial=True, one without. Could I instead reconstruct the total from a weighted sum of the partials? If so, what are the weights? Is it, as I suspect, x(A)^2 for A-A and 2 x(A) x(B) for A != B (presumably once I figure out the correct formula I can evaluate it with whatever strategy works for question 1)?
