Hello LAMMPS,
I would like to perform a quasi-static stretching simulation of Al using EAM potential in LAMMPS. My goal is to just stretch the sample and relax (minimize) it using a loop inside LAMMPS. So after the first cycle LAMMPS will write a data file of the minimized structure which I would like to read as a input of the second cycle. I wonder how to do it inside of a LAMMPS input script. My input file is attached below. In every cycle it is reading the initial data file not the latest one.
That’s b/c your read_data command uses the same filename
every pass thru the input script. If you give that file
a variable name, like relax_$y, then it can read a
different file each time. you probably need one variable
for x and another for
variable y equal x-1
Thanks Steve for your comment. But in order to make the data file name as a variable, I have to start the loop before read data comment. And if this is the case, it throws an error:
System init for write_data …
ERROR: Cannot read_data without add keyword after simulation box is defined (src/read_data.cpp:302)
Last command: read_data relax_${y}
New input script is below,
boundary p s p
atom_style atomic
variable disp equal 0.001
label loop
variable x loop 5
variable y equal ${x}-1
pair_style eam/alloy
pair_coeff * * Al99.eam.alloy Al
region 1 block INF INF 100 INF INF INF units box
group up region 1
timestep 0.001
thermo 100
thermo_style custom step temp press
variable stretch equal “v_disp*v_x”
displace_atoms up move 0.0 ${stretch} 0.0 units box
min_style cg
minimize 1e-3 1e-3 10000 100000
dump {x} all custom 10 dump.Al_* id type mass xs ys zs
run 1
write_data relax_{x}
next x
jump in.simple loop
Thanks for your help.
read_data will create a new box. you can only create a new box, if you
first delete the *entire* system beforehand with the "clear" command.
so try starting each iteration with "clear" and then repeat all
settings (boundary, atom_style, units and more).
for more information, please study the documentation. there are
examples and explanations.
