The simulation is running now. But according to the lammps manual we have to reuse the fix commands after using read_restart command. Manual says the fixes information are not stored in the restart file. So if I will not use “fix csinfo NULL CS-Info” after the “read_restart restart2” then will there be any loss of information? As I was using coreshell model and in the input file I was using the command
read_data file fix csinfo NULL CS-Info
to read the data file.
Here is a list of information not stored in a restart file, which means you must re-issue these commands in
your input script, after reading the restart file.
• fix commands (see below)
• compute commands (see below)
• variable commands
• region commands
• neighbor list criteria including neigh_modify settings
• kspace_style and kspace_modify settings
• info for thermodynamic, dump, or restart output
Regards
Omkar
