Dear LAMMPS users,
I am trying to verify the phonon dispersion curves for a given particular atomic coordinates, But to run the code, I am not able to generate the “map.in” file for the given data set.Although I, tried using latgen to produce the desired map.in file, but I am unable because, in the Graphene coordinates we don’t use any lattice parameters.We simply carry out the simulation on a 2D- Graphene sheet. So please help to generate the map.in file, in order to run the programme successfully. I have attached the coordinates file.
Thank You in advance.
datafile.xyz (39.8 KB)
