# Put fixed boundary condition on edge atoms by setting forces to zero
fix 2 gbhigh setforce 0 0 0
fix 3 gblow setforce 0 0 0
you are mixing two things up here. the two lines you quote refer to
immobilized atoms, not boundary conditions of the box.
2. What is difference between 'fix deform' command and
'displace_atoms'command?
fix deform changes the entire box geometry (and the atoms with them in a
way so they retain their relative position with respect to the box).
displace_atoms will only move atoms.
3. When I make tensile loading model my self, the material just 'moves' (I
could not plastic deformation even the force was not so strong)
What was problem?
who knows? probably your initial geometry was not proper.
Also, a fix, like fix deform operates
continuously during a run. Whereas displace_atoms
or displace_box is a one-time operation, done
before or between runs.
