Question about fix move command under shear deformation in LAMMPS
Hello. I am using LAMMPS (22 Jul 2025) on a Windows platform.
In a deformed simulation box, I want to move an atom along the x direction by a fixed distance.
Below is a simplified version of my input script:
variable        rate equal 0.1
units           lj
dimension       2
boundary        p p p
atom_style      atomic
lattice         sq2 0.8
region          box prism 0 71 0 71 -0.5 0.5 0.0 0.0 0.0
create_box      1 box
change_box      all xy final $(0.48*ly) units box
create_atoms    1 single 73 106 0 units box
create_atoms    1 single 56 56 0 units box
group           pinned_atoms id 1
mass            1 1.0
set             group pinned_atoms image 0 -1 0  # or 0 0 0
timestep        0.005
write_dump      all custom initial.dump id type x y z
fix             ref all store/state 0 x y z
variable        start_time equal $(step*dt)
variable        strain equal "v_rate*(step*dt-v_start_time)"
variable        x_aff atom "v_strain*f_ref[2]"
variable        aff_vec atom "v_rate*f_ref[2]"
fix             move_pinned pinned_atoms move variable v_x_aff NULL NULL v_aff_vec NULL NULL units box
run             1000
write_dump      all custom tst_move.dump id type x y z f_move_pinned[1] f_move_pinned[2]
I found that when the image flag of the atom to be moved is set to 0 0 0, the behavior is as expected:
The top atom moves to a larger x position.
fig1
However, when I set the image flag of the atom to 0 -1 0, the behavior is not as expected:
The atom does not move forward, but instead moves backward.
fig2
I understand that fix move uses unwrapped coordinates, so when the image flag is 0 -1 0, the starting position is different.
The starting position is located in the image -1 box rather than the image 0 box.
As a result, the top atom does not move forward, but backward.
My question is: Is this the expected behavior for fix move in LAMMPS?
In my opinion, the following behavior would be correct for a deformed box:
Thank you in advance for your help!
I suspect that your expectations are incorrect. Since you are using variables and not the “linear” mode, the question is really, whether you compute and feed to fix move what is commensurate with your expectations. From a cursory look it seems to me like your variable for the position update contains the position and not the displacement as described in the fix move documentation and that may be the origin of your confusion. Please also note, that your fix store/state stores the wrapped positions and not the unwrapped ones.
Thank you for your reply.
In my code, the displacements of particles are determined by the y - component of their vectors in the starting configuration. Specifically, atoms with a larger y - value experience a greater displacement.
To address this, I utilize the fix store/state command to preserve the initial positions of the particles. However, this approach is incompatible with the “linear” style of the fix move command, which relies on an “equal - style” variable. Under these circumstances, the expression for the atomic displacements should incorporate the initial position information. As shown in the figures above, the fix move command moves atoms by a fixed distance regardless of the box in which the atoms are located.
Since the fix move command stores unwrapped coordinates, the starting position should be in the image - 1 box. When an atom is remapped back to the origin (image 0) box, the mapping process should be consistent with the deformed box, which adheres to the periodic boundary condition (PBC) rule, in my opinion :slight_smile:
No, it does not. Only the “variable” style uses variables. You likely are misinterpreting the following statement in the documentation:
Note that the linear style is identical to using the variable style with an equal-style variable that uses the vdisplace() function
Actually, it does move forward. Only when you look at it, it has passed through the box and wrapped around periodic boundaries. See below for animations of your fix move applications. On the left for the 0 0 0 image flag case, and on the right for the 0 -1 0 image flags case.
move-image-0-0-0 move-image-0--1-0.
Nope. Atom positions are absolute.
Thank you very much for your patience. I have learned a great deal from your reply.
In the video on the right that you showed, the moving atom has a large displacement between frame 0 and frame 1.
This may cause the “lost atom” error. Such a large “jump” is presumably related to the mapping process between different image boxes.
Currently, as the documentation suggests, I have set the image of all atoms to 0 0 0 before invoking the fix move command.
This is not correct. What you call the first frame is the last.
Thank you very much. I sincerely appreciate your input. I’ll carefully examine the documentation regarding the fix move command.
When I refer to the “first” or “frame 0”, I’m specifically talking about the time order that can be obtained from the dump command.
Below, I’ve attached my updated input file where I’ve added the dump command.
units           lj
dimension       2
boundary        p p p
atom_style      atomic
lattice         sq2 0.8
create_box      1 box
mass            1 1.0
timestep        0.005
dump            record_motion all custom 10 move_process.dump id type x y z f_move_pinned[1] f_move_pinned[2]
run             1000
In my particular situation, frame 0 corresponds to Timestep 0, and frame 1 corresponds to Timestep 10.
I don’t have the time to debug your input for you. With using the variable option you get the positions that you feed fix move… If those are not what you want, the fault is not with LAMMPS.
