Hello everyone,
I am trying to calculate the thermal conductivity of an Inconel (Ni-Cr-Fe)/Cu multimetallic composite with an interface. I read that in order to get the electronic as well as the phononic contributions to the thermal conductivity, I have to use the two-temperature model, implemented using fix ttm in LAMMPS. Since thermal conductivity is an input parameter used by fix ttm, do I make a calculated guess for the thermal conductivity value that I use in fix ttm? And since I am calculating the thermal conductivity of my material, is there any other way to do this that does not involve having to specify a thermal conductivity as an initialized parameter? Thank you in advance.
Regards,
Rajesh
