I have an in file of lammps.
My purpose is to get Tg of CC, but it throws me error:
Total # of neighbors = 1676629
Ave neighs/atom = 331.61175
Ave special neighs/atom = 5.9367089
Neighbor list builds = 623
Dangerous builds = 0
ERROR: Cannot reset timestep with active dump - must undump first (src/output.cpp:636)
Last command: reset_timestep 0
Primary job terminated normally, but 1 process returned
a non-zero exit code. Per user-direction, the job has been aborted.
mpirun detected that one or more processes exited with non-zero status, thus causing
the job to be terminated. The first process to do so was:
Process name: [[39040,1],15]
Exit code: 1
Following is the input file.
Initialization
atom_style full
units real
pair_style lj/cut/coul/long 3.5 3.5
pair_modify mix geometric tail yes
kspace_style pppm/cg 1e-4
bond_style harmonic
angle_style harmonic
dihedral_style multi/harmonic
improper_style harmonic
special_bonds lj/coul 0.0 0.0 0.5
read_data data.lmps
neighbor 2.0 bin
thermo_style custom step temp density vol press ke pe ebond evdwl ecoul elong
thermo 1000
timestep 1
Minimization
min_style cg
minimize 1e-08 1e-10 10000000 1000000000
Equilibration
reset_timestep 0
dump dump_Equilibration all custom 10000 equil.lammpstrj id mol type q xs ys zs ix iy iz
restart 1560000 Equilibration.restart
fix fLANGEVIN all langevin 1000 1000 $(100.0*dt) 723853
fix fNVELIMIT all nve/limit 0.1
fix fMOM all momentum 100 linear 1 1 1 angular
run 10000
unfix fLANGEVIN
unfix fNVELIMIT
unfix fMOM
reset_timestep 0
fix step1 all nvt/sllod temp 1000 1000 $(100.0*dt)
run 50000
unfix step1
fix step2 all nvt/sllod temp 600 600 $(100.0*dt)
run 50000
unfix step2
fix step3 all npt/sllod temp 600 600 (100.0*dt) iso 986.92326 986.92326 (100.0*dt)
run 50000
unfix step3
fix step4 all nvt/sllod temp 1000 1000 $(100.0*dt)
run 50000
unfix step4
fix step5 all nvt/sllod temp 600 600 $(100.0*dt)
run 100000
unfix step5
fix step6 all npt/sllod temp 600 600 (100.0*dt) iso 29607.697799999998 29607.697799999998 (100.0*dt)
run 50000
unfix step6
fix step7 all nvt/sllod temp 1000 1000 $(100.0*dt)
run 50000
unfix step7
fix step8 all nvt/sllod temp 600 600 $(100.0*dt)
run 100000
unfix step8
fix step9 all npt/sllod temp 600 600 (100.0*dt) iso 49346.163 49346.163 (100.0*dt)
run 50000
unfix step9
fix step10 all nvt/sllod temp 1000 1000 $(100.0*dt)
run 50000
unfix step10
fix step11 all nvt/sllod temp 600 600 $(100.0*dt)
run 100000
unfix step11
fix step12 all npt/sllod temp 600 600 (100.0*dt) iso 24673.0815 24673.0815 (100.0*dt)
run 5000
unfix step12
undump dump_Equilibration
TgMeasurement
dump dump_TgMeasurement all custom 10000 Tg_measurement.lammpstrj id mol type q xs ys zs ix iy iz
restart 26000000 TgMeasurement.restart
variable Rho equal density
variable Temp equal temp
fix fDENS all ave/time 2500 100 500000 v_Temp v_Rho file temp_vs_density.txt
label loop
variable a loop ((450-250)/10+1)
variable b equal ((450-10*($a-1)))
unfix fDENS
fix fNPT all npt/sllod temp $b b (100.0dt) iso $b b (10b)
run ((5*10**6))
unfix fNPT
next a
jump SELF loop
variable a delete
undump dump_TgMeasurement
