question about melting point
Dear all friend
I want to calculate Gold melting point and I use EAM potential and this script :
atom_style atomic
atom_modify map array
# ---------- Create Atoms ---------------------
read_data Au256.data
# ---------- Define Interatomic Potential ---------------------
pair_style eam
pair_coeff * * Au_u3.eam
neighbor 2.0 bin
neigh_modify delay 10 check yes
# ---------- Define Settings ---------------------
compute eng all pe/atom
compute eatoms all reduce sum c_eng
# ---------- Run Minimization ---------------------
reset_timestep 0
fix 1 all box/relax iso 0.0 vmax 0.001
thermo 10000
min_style cg
minimize 1e-25 1e-25 5000 10000
#-----------------dynamic run in new temperature
dump npt all xyz 5000 ionized-npt.xyz
velocity all create 100 45827325 mom yes rot yes dist uniform
fix npt1 all npt temp 100.0 2000.0 0.01 y 1.0 1.0 500
fix 2 all momentum 10 linear 1 1 1 angular
fix 3 all recenter INIT INIT INIT units box
thermo_style multi
timestep 0.001
run 1000000
unfix npt1
undump npt
the gold structure is FCC and it has 256 atom
after run I draw potential energy v.s temperature curve but I see no
any jump in curve that show transition phase
I search in mailing list but i no find any thing
what is your suggestion?
best
Ehsan
How does your sample look like? Typically you need half box FCC and half
box random arrangement with the same density - i.e. amorphous liquid like.
Then you run for long time at a constant temperature and observe if the
FCC is slowly growing or shrinking. It tells you, if the temperature is
below or above the melting point, you are looking for.
Dear all friend
yes, because you are not accounting for finite size effects and the
fact, that melting is an activated process. the method you are trying
to use is seriously flawed. it only works in the macroscopic world
(and even there, you'll have to account for hysteresis effects in some
cases).
search again! and search smarter!!
the topic of determining the melting point of materials from MD
simulations has been discussed repeatedly on this very list and it
also has been explained that coexistence simulations are the proper
way to determine phase transition conditions on the atomic scale.
There is a script in examples/user for calculation of the melting point by two phase method from the work by Starikov S.V., Stegailov V.V. Premelting of iron and aluminum: implication for high pressure melting curve measurements // Phys. Rev. B., 2009, V. 80, P. 220104®.
