Question about setting a gaussian distribution of charge in granular sphere
The following code simulates a pour of granular spheres with a constant positive charge. I was wondering if there is a simple way to set a Gaussian distribution of charge instead.
It would be great if you could provide an example.
atom_style hybrid sphere charge # Agora permite cargas nas partículas
units si
boundary p p fm
newton off
comm_modify vel yes
Define variables for particles
variable idpackedbed equal 1
variable numpart equal 20
variable numpintloop equal 20
variable rnseed equal 123457
variable diam_mean equal 0.5
variable diam_std equal 0.0001
variable seed_diam equal 125632
variable phi equal 0.8 # packing fraction to fill the cavity
variable numtemps equal 10 # Number of attempts to insert new spheres
Define variables for box
variable boxpartscale_x equal 5
variable boxpartscale_y equal 30
variable boxpartscale_z equal 50
variable x0 equal 0
variable xf equal {boxpartscale_x}*{diam_mean}
variable y0 equal 0
variable yf equal {boxpartscale_y}*{diam_mean}
variable z0 equal 0
variable zf equal {boxpartscale_z}*{diam_mean}
Define regions
region simulation_box block {x0} {xf} {y0} {yf} {z0} {zf}
region box_injec block {x0} {xf} {y0} {yf} {z0} {zf}
create_box 2 simulation_box
Define list neighbors
neighbor 2 bin
neigh_modify delay 0
Define interaction
pair_style hybrid/overlay granular coul/cut 10.0
pair_coeff * * granular hertz 1000.0 50.0 tangential mindlin 1000.0 1.0 0.4
pair_coeff * * coul/cut 0.5 # Define interação de Coulomb com cutoff 0.5
Define timestep
timestep 0.0001
Define integration method
fix 1 all nve/sphere
Define gravitational field
fix 2 all gravity 9.81 vector 0 0 -1 # Gravidade atuando no eixo Z (para baixo)
Define Wall Interaction
fix zlower all wall/gran hooke/history 2000.0 NULL 50.0 NULL 0.5 0 zplane 0.0 NULL
dump mydmp all custom 100 dump.lammpstrj id type diameter q x y z vx vy vz omegax omegay omegaz fx fy fz
Define loop variable
variable varloop loop ${numpintloop}
label loop
variable seed1 equal floor(${varloop}*34512/10000) # Use different seeds each time
Generate a new random diameter for each iteration
variable diam_sphere equal normal({diam_mean},{diam_std},${seed1})
Insert particles with random sizes
fix mypour5 all pour {numpart} 1 {seed1} vol {phi} {numtemps} &
region box_injec diam one ${diam_sphere}
run 1000 # Short run after particle insertion
Assign charge to newly inserted particles (now that atoms exist)
set group all charge 1e-15
next varloop
jump SELF loop
run 80000 # Final longer run
write_data last_step_sim.rest
Please check out this post: Please Read This First: Guidelines and Suggestions for posting LAMMPS questions
It explains basic guidelines for posting here and that includes how to properly typeset quoted text, so that it is properly readable. Yours is not. Didn’t you notice??
If you want a assign a non-uniform charge, you need to replace “1e-15” in
with a reference to an atom style variable that uses and expression based on either the “normal()” function to create a random gaussian distribution, or some other expression that would compute the charge for the individual atom based on its position in the box or similar. Please see the documentation for the “set” and the “variable” commands for details.
