Dear LAMMPS developers and users,
I am currently using the fix atom/swap command in LAMMPS for Monte Carlo atom exchange simulations, and I would like to better understand the role of the NX parameter.
According to the documentation, the syntax of fix atom/swap includes the parameter:
fix ID group-ID atom/swap N X seed T ...
where N is the number of MD timesteps between Monte Carlo swap attempts, and X (NX) is the number of swap attempts performed during each MC step.
I would like to ask for clarification on the following questions:
How should the value of NX be determined in practice?
Is there a recommended relationship between NX and the total number of atoms, concentration of the swapped species, or system size? -
What is the physical effect of changing NX?
For example, if NX is increased while keeping other parameters unchanged:-
Does it only increase the number of attempted swaps per MC cycle and therefore accelerate sampling?
Could a very large NX introduce any bias or affect the equilibrium state obtained from the simulation?
Is there a commonly used criterion to judge whether NX is sufficiently large for MC/MD simulations?
For example, should NX be related to the number of atoms of the minority species or a certain fraction of the total number of atoms? -
In a system with approximately N atoms, if the goal is to achieve good chemical equilibration through atom swaps, would setting:
NX = N
(or a similar order of magnitude) be considered reasonable?
I would appreciate any guidance or practical experience regarding the selection of NX in fix atom/swap simulations.
Thank you very much for your time and help.
Best regards.
