I’m trying to calculate the energy above hull by pymatgen, while the error, as shown in the following figure, occurs frequently.
What should i do to solve this problem?
Hi @Guancred , the line NoneType object has no attribute energy_adjustments indicates to me that either computed_entry or mp_entries is None. Inspect both of those and make sure that they are each ComputedEntry objects. Good luck!
Thank you sir, may be this error is attributed to the vasprun.xml file, when i use another vasprun.xml, this error did not occur.
Dear Guancred,
I have same problem with you in this error,
How I can slove this error in my code?
Thank you so much for helping!
Dear rkingsbury,
I am also have this erorr for computed_entry of vasprun.xml,
So can I remove the energy adjustment by any Pymatgen code?
Thank for helping!
this error may be caused by the format of the vasprun.xml
I am also having this error but both my computed_entry and mp-entries is not NONE still the error persisits. What should I do to resolve this ?
