Thanks, Steve!
I will check that using pair_write, and post it to the list in case it does not show the expected behaviour.
Peter
Thanks, Steve!
Peter
Hi Peter,
Did you solve this problem? I also encounter the same problem when I try to shift to specific pair_style, not all the pair_styles with the hybrid command.
Thanks so much.
Hi Peter,
command.
how about reading the documentation?
Hi Axel,
Thanks. I have checked the doc about pair_modify. However pair_modify shift applied all substyles of hybrid pair style, not specific substyle.
Hi Axel,
you need to learn to read more carefully. you have obviously
overlooked the pair flag.
you can very well selectively apply the shift to pair styles, for as
long as they support it.
