Dear LAMMPS users,
I’m trying to use pairstyle table. In the manual there is some explanation on the file that we should use as the input of the potential. First, should I necessarily include force component as well as potential at each distance ? I tried to do the simulation without including force at each distance and it only give me warning as follow:
W****ARNING: 5800 of 5800 distance values in table with relative error
over 1e-006 to re-computed values (…/pair_table.cpp:490)
The formula that I have for the potential is in a way that I prefer not to calculate its derivative to calculate force because of its complexity. Moreover, since we use Verlet integration I doubt that the force is a requirement. Rather I guess it is only for the accuracy.
Another thing is that the simulation cannot change the box too much too reach to the desired pressure:
Step Lx Ly Lz Press Pxx Pyy Pzz Pxy Pxz Pyz PotEng Temp Density Volume
0 7.6090002 6.5895872 2.908 -382581.75 -366914.02 -367016.96 -413814.26 -14.134249 1.1799159e-010 1.4346748e-010 2453.3368 0 3.1955163 145.80762
1 7.6022536 6.5837428 2.905092 -382845.79 -367271.63 -367373.81 -413891.94 166.77058 -3.0889215e-011 1.6468195e-010 2451.0758 0 3.2043958 145.40358
2 7.5955024 6.5778945 2.902184 -383093.48 -367615.77 -367716.7 -413947.97 351.38823 -7.8587978e-012 3.1914386e-011 2448.8139 0 3.213312 145.00012
3 7.5921245 6.5749683 2.90073 -383211.09 -367782.67 -367882.86 -413967.73 445.15562 -1.5443877e-010 4.4368037e-011 2447.6824 0 3.2177845 144.79858
4 7.590435 6.5735048 2.900003 -383268.21 -367864.76 -367964.54 -413975.33 492.36974 1.1040666e-010 1.9763907e-010 2447.1166 0 3.2200244 144.69785
5 7.5904284 6.573499 2.9000002 -383268.43 -367865.08 -367964.86 -413975.36 492.5545 4.9710024e-011 -1.9245347e-010 2447.1144 0 3.2200331 144.69746
6 7.5904282 6.5734989 2.9000001 -383268.44 -367865.09 -367964.87 -413975.36 492.56028 2.3625709e-011 4.3044889e-011 2447.1143 0 3.2200334 144.69745
7 7.5904281 6.5734988 2.9 -383268.44 -367865.09 -367964.87 -413975.36 492.56316 8.6666019e-011 1.9089766e-010 2447.1143 0 3.2200335 144.69744
8 7.590428 6.5734987 2.9 -383268.44 -367865.09 -367964.88 -413975.36 492.56461 -8.9931363e-011 7.8944447e-011 2447.1143 0 3.2200336 144.69744
9 7.590428 6.5734987 2.9 -383268.44 -367865.09 -367964.88 -413975.36 492.56479 -3.7301732e-011 -5.2482691e-010 2447.1143 0 3.2200336 144.69744
10 7.590428 6.5734987 2.9 -383268.44 -367865.09 -367964.88 -413975.36 492.56488 1.9860963e-011 -7.5659898e-011 2447.1143 0 3.2200336 144.69744
11 7.590428 6.5734987 2.9 -383268.44 -367865.09 -367964.88 -413975.36 492.56488 1.9860963e-011 -7.5659898e-011 2447.1143 0 3.2200336 144.69744
Loop time of 0.0830579 on 1 procs for 11 steps with 14 atoms
Finally, nothing change during equilibration toward 0 pressure:
0 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
1000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
2000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
3000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
4000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
5000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
6000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
7000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
8000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
9000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
10000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
11000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
12000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
13000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
14000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
15000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
16000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
17000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
18000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
19000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
20000 7.590428 6.5734987 2.9 -382028.03 -366717.35 -367001.1 -412365.65 212.60573 271.53689 -534.98751 2447.1143 100
Any comment would be really helpful.
Ali
