I am trying to use a do-loop to deposit clusters of nickel atoms onto a CNT substrate (which is read from an outside file). I am running into a group limit of 32 groups, and was wondering if there was a way to overcome this.
If I created random atoms one-by-one, could I assign them velocities without assigning them to a group?
Would the fix_deposit command help overcome this limit?
My code is shown below:
##—————INITIALIZATION——————————-
atom_style atomic
variable latparam equal 3.52
----------------------- ATOM DEFINITION ----------------------------
read_data input.atoms
region CNT block 0 40 0 40 0 50
group CNT region CNT
##—————SETTINGS———————————
pair_style hybrid airebo 3.0 eam/alloy morse 3.0
pair_coeff * * airebo CH.airebo C NULL
pair_coeff * * eam/alloy Ni99.eam.alloy NULL Ni
pair_coeff 1 2 morse 0.234 1.975 2.27 3.0
mass 1 12.0111
mass 2 58.6934
minimize 1.0e-10 1.0e-10 10000 10000
dump 65 all xyz 100 dump.xyz
reset_timestep 0
timestep 0.001
velocity all create 300 12345 mom yes rot no
fix 1 all nvt temp 300 300 100 drag 1
fix 2 CNT momentum 10 linear 1 1 1
fix 3 CNT momentum 10 angular
thermo 20
thermo_style custom step temp
run 20
unfix 1
----------------------- NCs DEPOSITION ----------------------------
reset_timestep 0
fix 1 all npt temp 300 300 1 z 0 0 100 drag 1
variable max equal 45
variable i loop {max}
variable pos equal 45
variable p loop {pos}
label loop1
print “Cluster i=$i”
region {i} sphere 0 15 {p} 1.76 units box
lattice fcc {latparam} orient x 1 1 0 orient y -1 1 0 orient z 0 0 1
create_atoms 2 region {i}
group {i} region {i}
velocity ${i} set 0 -0.8 0
run 1000
next p
next i
jump TestDo.txt loop1
Alex
