I am using Ovito Python to do post-processing. I tried to select one atom type and delete it. After doing other operations, I then exported the system as a new lammpsdata file. The first few lines look like
# LAMMPS data file written by OVITO Pro 3.8.4
15800 atoms
5 atom types
0.7271978455 83.0218274363 xlo xhi
0.7271978455 73.0218274363 ylo yhi
0.7271978455 73.0218274363 zlo zhi
But actually, now it should be ‘4 atom types’. Yes, I can change it manually, however, I wonder if I can change it in the script and directly output an appropriate file.
Thanks a lot!
Fan
If you want OVITO to “forget” about a particle type that is part of the File Source, you also actively need to edit the types
list, which is attached to the Particle Type Property
array, e.g. like this
for i,type in enumerate(data.particles.particle_types.types):
if type.id == 2:
del data.particles_.particle_types_.types[i]
More on so-called typed-properties here:
https://www.ovito.org/docs/current/reference/pipelines/data_objects/particles.html#scene-objects-particle-types
https://www.ovito.org/docs/current/python/modules/ovito_data.html#ovito.data.Property
https://www.ovito.org/docs/current/python/modules/ovito_data.html#ovito.data.ParticleType
Thank you for your detailed instructions and information. It helps a lot.
Fan
