Hi dear
I would thanks for your excellent provided code.I am one of fans of
your code and would use it in my thesis. My thesis is about simulation
of polymer nanocomposite. I have a few problem with it. First, I don't
know how do I define a polymer molecule in LAMMPS? Second, for
embedding a nano particle in polymer matrix, should I define the
region?
please guide me. before ahead I thanks for your help. I'm looking
forward to your answer.
Hi dear
use or write an external tool that generates a data file.
check out the tools/chain.f file for a simplistic example.
region?
again, this is something that is likely to be best done externally,
by generating a polymer matrix with a suitable hole and then
building the composite. to handle potential overlaps, you may
start the simulation using a "soft" potential, that is turned on
gradually.
please also talk to your advisor. the kind of problem that you
are asking to get help with, is usually something that is _supposed_
to be explained to you by your advisor. that is their job, not ours.
