Dear All,
Erhart and Albe have published some so called analytical bond-order
potentials (ABOP) for different materials. ABOP has a form similar to
Tersoff potential, thus can be converted. I have two questions about ABOPs:
(1) Following is a SiC Tersoff potential file converted from an ABOP in
the LAMMPS package (file name: SiC_Erhart-Albe.tersoff):
# Si and C mixture, parameterized for Tersoff potential
# this file is from ulomek(at)imm.rwth-aachen.de
# values are from Erhart/Albe - Phys Rev B, 71, 035211 (2005)
# m=n=beta=1
# R,D,gamma,c,d ->same
# lambda1=beta*sqrt(2*S)
# lambda2=beta*sqrt(2/S)
# lambda3=2*mu=0
# costheta0=-h
# A=D0/(S-1)*exp(lambda1*r0)
# B=S*D0/(S-1)*exp(lambda2*r0)
# Tersoff parameters for various elements and mixtures
# multiple entries can be added to this file, LAMMPS reads the ones it
needs
# these entries are in LAMMPS "metal" units:
# A,B = eV; lambda1,lambda2,lambda3 = 1/Angstroms; R,D = Angstroms
# other quantities are unitless
# format of a single entry (one or more lines):
# element 1, element 2, element 3,
# m, gamma, lambda3, c, d, costheta0, n,
# beta, lambda2, B, R, D, lambda1, A
C C C 1 0.11233 0 181.91 6.28433 -0.5556 1 1 1.93090093 175.426651
2 0.15 4.18426232 2019.8449
Si Si Si 1 0.114354 0 2.00494 0.81472 -0.259 1 1 1.53810493 219.521624
2.82 0.14 2.83318929 2145.7128
Si C C 1 0.011877 0 273987 180.314 -0.68 1 1.76807421 225.189481 2.4
0.2 3.26563307 1779.36144
C Si Si 1 0.011877 0 273987 180.314 -0.68 1 1 1.76807421 225.189481
2.4 0.2 3.26563307 1779.36144
Si Si C 1 0.011877 0 273987 180.314 -0.68 0 0 0 2.4 0.2 0 0
C C Si 1 0.011877 0 273987 180.314 -0.68 0 0 0 0 2.4 0.2 0 0
C Si C 1 0.11233 0 181.910 6.28433 -0.5556 0 0 0 0 2 0.15 0 0
Si C Si 1 0.114354 0 2.00494 0.81472 -0.259 0 0 0 0 2.82 0.14 0 0
I was wondering if there is an error in this potential file: according to
LAMMPS' manual, the first element should be the atom in the middle, the
second is the one connect to it, and the third one has an influence to the
bond between the first two elements. So I was wondering if the last four
lines should be:
C Si C 1 0.011877 0 273987 180.314 -0.68 0 0 0 2.4 0.2 0 0
Si C Si 1 0.011877 0 273987 180.314 -0.68 0 0 0 0 2.4 0.2 0 0
C C Si 1 0.11233 0 181.910 6.28433 -0.5556 0 0 0 0 2 0.15 0 0
Si Si C 1 0.114354 0 2.00494 0.81472 -0.259 0 0 0 0 2.82 0.14 0 0
However, according to the original paper, only the nearest neighbor is
considered. Therefore, the last four lines actually never count if a
simulation is ran under a mild temperature and pressure condition, and
writing them out is just let LAMMPS to recognize them. I am not sure if I
am correct.
Yes, you are correct. The converter is not correct in the conversion as
well.
(2) There is also a ABOP developed for ZnO (Paul Erhart *et al* 2006 *J.
Phys.: Condens. Matter* *18* 6585). Similarly, I converted it to a
Tersoff form by my self:
Zn Zn Zn 1.0 0.000043909 0.0 77.916 0.91344 -1.0 1.0 1.0 1.7965
115.16 2.85 0.2 3.2614 2258.7
O O O 1.0 0.82595 0.0 0.035608 0.046496 -0.45056 1.0 1.0
2.7733 527.65 2.45 0.2 3.8449 1388.1
O Zn Zn 1.0 0.019335 0.0 0.014108 0.084028 -0.30545 1.0 1.0
2.5136 6304.3 2.6 0.2 2.6280 7344.2
Zn O O 1.0 0.019335 0.0 0.014108 0.084028 -0.30545 1.0 1.0
O Zn O 1.0 0.019335 0.0 0.014108 0.084028 -0.30545 0 0 0 0
2.6 0.2 0 0
Zn O Zn 1.0 0.019335 0.0 0.014108 0.084028 -0.30545 0 0 0 0
2.6 0.2 0 0
Zn Zn O 1.0 0.000043909 0.0 77.916 0.91344 -1.0 0 0 0 0 2.85
0.2 0 0
O O Zn 1.0 0.82595 0.0 0.035608 0.046496 -0.45056 0 0 0 0
2.45 0.2 0 0
I hope I haven't made any stupid mistake, because I obtained similar
results of the lattice parameters and cohesive energy of wurtzite-ZnO by a
lattice statics simulation. The problem is, when I preform a MD simulation
at even 300 K, the wurtzite structure of ZnO collapsed. I was wondering if
I did something wrong or the potential itself is not suitable for MD
simulations?
The potential file looks alright to me. But nobody can know if it is a
good potential for finite temperature MD.
