Questions about convex hull constructions with ternary compounds
I have a few questions about the convex hull construction with ternary compounds. As I can see from ICET tutorial, the ConvexHull function is mostly used with binaries, where there’s only one independent concentration. However, my current system is a Ti-C-N-Vac ternary system, where [[Ti], [C, N, X]] Ti atoms takes one sulattice and C, N, Vacancies take another sublattice. I wonder if the ConvexHull function work well for such a system?
If so, which concentration should I use? (sublattice concentration or the element total concentration?) For the Ti-C-N system, the sublattice concentration of Ti is always 1.0, so I think using sublattice concentration doesn’t work here. I’m a bit confused about this part right now. Would you please show me how I should set the concentration correctly in this function?
Thank you so much. Look forward to your reply.
Im not sure about this, maybe can check out the code and discussion here An example using ASE's PhaseDiagram for convex hull energies (#615) · Issues · materials-modeling / icet · GitLab
and possibly Michael would know more about this.
