I have questions about minimum relative distance and OPsiteFingerprint.
After I use the minimum relative distance, it simply gives me a set of numbers, but how can I know which number corresponds to which site in the crystal?
Also, after I use OPsiteFingerprint, all I get are a bunch of NaN. I am looking at Si crystals so there should at least some data for tetrahedral sites, but in the output, it is still only NaN. Are there arguments I need to adjust in order to get meaningful data?
The minimum relative distances are in the same order as the sites in the structure when iterated over. For example:
mrd = MinimumRelativeDistances()
mrd_array = mrd.featurize(structure)[0]
for i in range(len(structure.sites)):
print("distance {} corresponds to site {}:{}".format(mrd_array[i], i, structure.sites[i]))
Regarding OPSiteFingerprint, could you post the code you are using which is throwing nan? It is working for me, but there may be a bug in the code that we are unaware of.
Alex
On Friday, October 26, 2018 at 2:00:11 PM UTC-7, Jason wrote:
Hi
Note also that we generally recommend CrystalNNFingerprint.from_preset(“ops”) rather than OPSiteFingerprint. We may deprecate OPSiteFingerprint in a future release as CrystalNNFingerprint is shown to produce more reliable neighbor finding, while retaining the order parameters.
from matminer.featurizers.site import OPSiteFingerprint
feat=OPSiteFingerprint(dr=0.5,ddr=0.1,dop=0.01)
feat.featurize_dataframe(data,‘structure’,ignore_errors=True)
I also use this code for VoronoiFingerprint which doesn’t work as well.
在 2018年10月27日星期六 UTC-5上午12:06:41,a…@lbl.gov写道:
Hi jason,
Alex
Hi
It seems like you are using OPSiteFingerprint on structure objects without using the site index.
The featurize function for all site featurizers is:
def featurize(self, struct, idx):
This means the structure and the index must be passed to any featurize_* method.
If you want statistics of the OPSiteFingerprint over all sites in a structure, you should use SiteStatsFingeprint in featurizers.structure.
As Anubhav mentioned in another thread though, it is preferred to use CrystalNNFingerprint instead.
On Monday, October 29, 2018 at 8:09:19 AM UTC-7, Jason wrote:
Hi Alex:
The code I’m using is like below:
Hi jason,
Alex
Hi
Also a helpful tip for debugging: ignore_errors=False will tell you what is going wrong. When ignore_errors = True, all errors are ignored and nan is inserted as the value.
So because you are not passing a site index to a Site featurizer, but ignore_errors is True, you are getting all nan.
Hi Alex:
Hi jason,
Alex
Hi
