I’m running a test example for submitting to a slurm queue:
from fireworks.queue.queue_launcher import rapidfire as rapidfirequeue
from fireworks.queue.queue_launcher import launch_rocket_to_queue
from fireworks.core.fworker import FWorker
import fireworks.fw_config
from fireworks.utilities.fw_serializers import load_object_from_file
from fireworks import Firework, Workflow, LaunchPad, ScriptTask
qadapter = load_object_from_file(fireworks.fw_config.QUEUEADAPTER_LOC)
launchpad = LaunchPad()
launchpad.reset(’’, require_password=False)
fw1 = Firework(ScriptTask.from_str(‘echo “hello” >> hello.txt’))
fw2 = Firework(ScriptTask.from_str(‘echo “goodbye” >> goodbye.txt’))
wf = Workflow([fw1,fw2], name=“test workflow”)
launchpad.add_wf(wf)
rapidfirequeue(launchpad,FWorker(),qadapter)
my qadapter file looks like:
_fw_name: CommonAdapter
_fw_q_type: SLURM
rocket_launch: rlaunch -w /home/mattsj/my_fworker.yaml -l /home/mattsj/my_launchpad.yaml singleshot
ntasks: 1
cpus_per_task: 8
walltime: ‘5-00:00:00’
queue: month-long-cpu
account: mattsj
job_name: null
logdir: /home/mattsj/fw_logs
pre_rocket: null
post_rocket: null
fworker file is an exact copy of the tutorial example
I’m on version 2.0.3 from conda-forge.
When I run the above python script in the FW_job.out file in the output files I get:
No FireWorks are ready to run and match query! {’$or’: [{‘spec._fworker’: {’$exists’: False}}, {‘spec._fworker’: None}, {‘spec._fworker’: ‘my first fireworker’}]}
Dumping the fireworks afterwards to dictionaries I get:
{‘spec’: {’_tasks’: [{‘script’: [‘echo “hello” >> hello.txt’],
‘use_shell’: True,
‘_fw_name’: ‘ScriptTask’}]},
‘fw_id’: 2,
‘created_on’: ‘2022-07-11T21:19:46.133113’,
‘updated_on’: ‘2022-07-11T21:19:46.138695’,
‘state’: ‘READY’,
‘name’: ‘Unnamed FW’}
and
{‘spec’: {’_tasks’: [{‘script’: [‘echo “goodbye” >> goodbye.txt’],
‘use_shell’: True,
‘fw_id’: 1,
‘created_on’: ‘2022-07-11T21:19:46.133171’,
‘updated_on’: ‘2022-07-11T21:19:46.138699’,
‘state’: ‘READY’,
So it seems to not be running them because it thinks the current FWorker isn’t suitable.
