I am trying to run quip pair_style in lammps ( 9 Nov 21) to perform MD using my trained gap potential. I trained GAP potential for sodium data using distance_2b and soap as descriptors. But when I run the input file, I get the following warnings and no data are given.
WARNING: No pairwise cutoff or binsize set. Atom sorting therefore disabled. (src/atom.cpp:2179)
WARNING: Communication cutoff is 0.0. No ghost atoms will be generated. Atoms may get lost. (src/comm_brick.cpp:209)
The relevant part of LAMMPS input script:
pair_style quip
pair_coeff * * gap_example.Na.xml “Potential xml_label=GAP_2021_12_24_210_5_59_39_424” 11
neighbor 0.2 bin
neigh_modify delay 10
fix 1 all nvt temp 300.0 300.0 50.0
thermo 1
timestep 0.001
while the example part in lammps package runs very well.
I have no idea how to fix this and would appreciate any help.
Thank you
