Qull wide merge error
I met this error when I’m trying to use PhaseDiagram(entries), I got this error:
My code worked for other chemsys entries in the for loop, could anyone helped me with this issue?Many thanks.
pd = PhaseDiagram(entries)
  File "/home/lib/python3.11/site-packages/pymatgen/analysis/phase_diagram.py", line 380, in __init__
    computed_data = self._compute()
  File "/home/lib/python3.11/site-packages/pymatgen/analysis/phase_diagram.py", line 474, in _compute
    facets = get_facets(qhull_data)
  File "/home/lib/python3.11/site-packages/pymatgen/analysis/phase_diagram.py", line 2058, in get_facets
    return ConvexHull(qhull_data, qhull_options="Qt i").simplices
  File "_qhull.pyx", line 2425, in scipy.spatial._qhull.ConvexHull.__init__
  File "_qhull.pyx", line 343, in scipy.spatial._qhull._Qhull.__init__
scipy.spatial._qhull.QhullError: QH6271 qhull topology error (qh_check_dupridge): wide merge (15330210.7x wider) due to dupridge between f925 and f924 (vertex dist 0.17), merge dist 0.096, while processing p11
- Allow error with option 'Q12'
ERRONEOUS FACET:
- f925
    - flags: top newfacet mergehorizon dupridge mergeridge2
    - normal:   -0.9864        0       -0   0.1644       -0
    - offset:         -0
    - vertices: p11(v45) p4(v44) p15(v35) p54(v27) p61(v6)
    - neighboring facets: f865 f28 f926 f924
    - ridges:
     - r1342 simplicialtop simplicialbot
           vertices: p4(v44) p15(v35) p54(v27) p61(v6)
           between f925 and f865
     - r1343 simplicialbot
           vertices: p11(v45) p15(v35) p54(v27) p61(v6)
           between f865 and f925
     - r1346 simplicialtop
           between f925 and f28
     - r1344 simplicialtop simplicialbot
           vertices: p11(v45) p4(v44) p54(v27) p61(v6)
           between f925 and f926
     - r1345 simplicialbot
           vertices: p11(v45) p4(v44) p15(v35) p61(v6)
           between f924 and f925
ERRONEOUS OTHER FACET:
- f924
    - flags: top newfacet mergehorizon dupridge mergeridge1
- normal:    0.4789   0.4789   0.4789   0.5587       -0
    - offset: -0.4788521
    - vertices: p11(v45) p4(v44) p24(v36) p15(v35) p61(v6)
    - neighboring facets: f717 f925 f28 f926 f636
    - ridges:
     - r1329 tested simplicialtop
           vertices: p4(v44) p24(v36) p15(v35) p61(v6)
           between f924 and f717
     - r1341 simplicialtop
           between f924 and f28
     - r1340 simplicialtop simplicialbot
           vertices: p11(v45) p4(v44) p24(v36) p61(v6)
           between f926 and f924
     - r1339 simplicialtop simplicialbot
           vertices: p11(v45) p24(v36) p15(v35) p61(v6)
           between f636 and f924
While executing:  | qhull i i Qt
Options selected for Qhull 2019.1.r 2019/06/21:
  run-id 1522070417  incidence  incidence  Qtriangulate  Qxact-merge
  _zero-centrum  _max-width 3.6e+05  Error-roundoff 4.8e-10  _one-merge 5.3e-09
  _near-inside 2.6e-08  Visible-distance 2.9e-09  U-max-coplanar 2.9e-09
  Width-outside 5.8e-09  _wide-facet 1.7e-08  _maxoutside 5.8e-09
Last point added to hull was p11.  Last merge was #403.
At error exit:
Convex hull of 86 points in 5-d:
  Number of vertices: 45
  Number of coplanar points: 24
  Number of facets: 159
  Number of non-simplicial facets: 28
Statistics for:  | qhull i i Qt
  Number of points processed: 45
  Number of hyperplanes created: 491
  Number of distance tests for qhull: 7663
  Number of distance tests for merging: 8890
  Number of distance tests for checking: 0
  Number of merged facets: 442
  Maximum distance of point above facet: 6.1e-09 (1.1x)
  Maximum distance of vertex below facet: -3.1e-09 (0.5x)
precision problems (corrected unless 'Q0' or an error)
      1 flipped facets
    152 coplanar horizon facets for new vertices
     24 coplanar points during partitioning
     16 nearly singular or axis-parallel hyperplanes
     14 zero divisors during back substitute
     35 zero divisors during gaussian elimination
      1 dupridges with multiple neighbors
A wide merge error has occurred.  Qhull has produced a wide facet due to facet merges and vertex merges.
