For example, this is an output for 1 and 2 processors (identical results):
Component: -1.01982
Component: -1.02193
Component: -1.02399
Component: -1.03146
Component: -1.0334
Component: -1.03527
Component: -1.02494
Component: -1.02673
Component: -1.03225
Component: -1.03345
but when I switch to 4 processors I get:
Component: -0.345621
Component: -0.350271
Component: -0.359292
Component: -0.356795
Component: -0.360651
Component: -0.367863
Component: -0.372585
Component: -0.377683
Component: -0.375943
Component: -0.380856
, that is a big difference...
----Messaggio originale----
Da: [email protected]
Data: 11/11/2013 19.02
A: "[email protected]"<[email protected]>
Cc: "LAMMPS Users Mailing List"<[email protected]>
Ogg: Re: [lammps-users] manual outputHello to all Lammps users!
I've got a programming question. Let's say that I modify the file:
compute_heat_flux.cpp
introducing these lines:
if (universe->me == 0) {
std ::ofstream myfile;
myfile.open ("file.dat",std::ios_base::app);myfile << "Component: " << vector[3]<< "\n";
myfile.close();
---------------------------------just after the MPI_All_Reduce in ComputeHeatFlux::compute_vector().
In my mind the output file should be indipendent of the number of
processors I
use but I do not observe this. I get the same number for one and two
processors, but from three the numbers are different. Is there something
wrong?
