Thanks a lot,
----Messaggio originale----
Da: [email protected]
Data: 19/08/2014 16.50
A: "[email protected]..."<[email protected]...>
Cc: "LAMMPS Users Mailing List"<[email protected]>
Ogg: Re: [lammps-users] new pair style and current computationHello,
I have a new radial, two body pair style in lammps, obtained modifying
pair_morse.cpp and pair_morse.h. Everything seems to work well, but I
wanted to
ask if there can be compatibility issues with the heat current computation
(compute_heat_flux.cpp) and if there is something to be modified that can
be
tricky (I have no runtime errors).
fix heat operates on the kinetic energy,
Sorry, maybe there is a misunderstanding, I'd like to use the heat/flux
command not the fix heat
http://lammps.sandia.gov/doc/compute_heat_flux.html
this command requires correct computation of virial and atomic energies
