Dear Lammps users,
I am using Lammps to simulate a system of colloidal particles. I am using Langevin dynamics simulation dynamics. I see that in fix_langevin.cpp the random force used is generated using uniform random number and it is calculated as gamma2*(random->uniform()-0.5). I would assume that this would generate random number between -0.5 to 0.5. Suppose I need to have a temperature of 1.0 how this will make sure that I get that value 1.0. Or <r_i(t)r_i(t’)=\del(t-t’) is obtained in this case. Am I missing something multiplication factor ?
In general I think that in-order to get a value of 1.0 I should 2.0(random->uniform()-1.0) right for a brownian or langevin simulation.
Thank you
Parvathy
Dear Lammps users,
I am using Lammps to simulate a system of colloidal particles. I am using Langevin dynamics simulation dynamics. I see that in fix_langevin.cpp the random force used is generated using uniform random number and it is calculated as gamma2*(random->uniform()-0.5). I would assume that this would generate random number between -0.5 to 0.5. Suppose I need to have a temperature of 1.0 how this will make sure that I get that value 1.0. Or <r_i(t)r_i(t')=\del(t-t') is obtained in this case. Am I missing something multiplication factor ?
yes, you even quoted it. the magic is in the value of "gamma2". you
won't get a number between -0.5 and 0.5 but between -gamma2*0.5 and
gamma2*0.5
your thinking is wrong.
Dear Lammps users,
Thank you axel for the mail.
Dear Lammps users,
yes, you even quoted it. the magic is in the value of “gamma2”. you
won’t get a number between -0.5 and 0.5 but between -gamma2*0.5 and
The factor gamma2 has value gamma2 = gfactor2[i]*tsqrt;
gfactor2[i] = sqrt(atom->mass[i]) *
sqrt(24.0*force->boltz/t_period/update->dt/force->mvv2e) /
force->ftm2v;
And LAMMPS documentation says Fran is proportional to sqrt(Kb T m / (dt damp)) . Can you please explain why there is a factor 24 ?
sorry I meant this 2*random->uniform()-1.0 to get the temperature to be one ? That generate values between -1 to 1 rather than -0.5 to -0.5
Best Regards:
Parvathy.
sorry, but this is not the place to give you a lecture on how a
langevin thermostat is derived and implemented. please refer to the
published literature and text books instead. i am quite confident,
that the implementation is correct.
For factor 24, see this post from Steve from almost 10 years ago: https://lammps.sandia.gov/threads/msg09923.html
