Dear Lammps users,
I am trying to select a certain number of atoms as PKAs using the following commands:
group select empty
group PKAstore empty
variable numPKA equal count(PKAstore)
variable n loop 500
variable check atom grmask(Si,FREE)
label jump
variable select equal (random(1,atoms,4224):%.0f)
variable a equal (v_check[v_select])
if “v_check[v_select] == 1” then &
“group PKAstore id {select}"
if "{numPKA}<10” then &
“next n” &
“jump SELF jump”
variable n delete
However, I ran into the following error:
ERROR: Indexed per-atom vector in variable formula without atom map. (…/variable.cpp:4604)
Last command: variable a equal $(v_check[v_select])
I have looked up LAMMPS manual and added “atom_modify map yes id yes”in my input, yet the error still exists. I don’t know how to fix this atom mapping problem, and if there is a better way to select a certain number of atoms randomly within a specified group and region?
Many thanks for any suggestion!
Best wishes,
Dingyu
The whole in script is as follows:
variable T1 equal 300.0 # K
variable RDN equal 4928459
variable PROD equal 10000 #100ps test
variable dt1 equal 0.1
variable P1 equal 1.0
variable Tpka equal 55830.0
units real
atom_style charge
read_restart PHPS50_slab_Eq300K.restart
pair_style reaxff lmp_control safezone 32 mincap 2000 minhbonds 1000
pair_coeff * * ffield N Si H
fix 1 all qeq/reaxff 1 0.00 10.00 1e-6 reaxff
neighbor 2.0 bin
neigh_modify every 10 delay 0 check yes
balance 1.1 shift z 10 1.05
timestep ${dt1}
reset_timestep 0
region BOTTOM block INF INF INF INF INF -16.0 units box
region FREE block INF INF INF INF -16.0 23.0 units box
region SURF block INF INF INF INF 10.0 23.0 units box
group BOTTOM region BOTTOM
group FREE dynamic all region FREE
group SURF region SURF
group FREEstatic region FREE
group N type 1
group Si type 2
group H type 3
group FREESi intersect Si FREEstatic
group SURFSi intersect Si SURF
#randomly select a Si PKA
group select empty
variable n loop 500
label jump
“next n” &
“jump SELF jump”
variable n delete
velocity BOTTOM set 0.0 0.0 0.0
fix FREEZE BOTTOM setforce 0.0 0.0 0.0
fix spec all reaxff/species 1 1 100 species_0_1000_ps.out element N Si H &
delete species.del masslimit 0 47
fix bond all reaxff/bonds 1000 bonds_0_1000_ps.reax
compute mytemp FREE temp
compute_modify mytemp dynamic/dof yes
thermo_style custom step time atoms temp c_mytemp pe ke evdwl ecoul etotal press xlo xhi ylo yhi zlo zhi cpuremain
thermo 1000
dump 1 all custom 10000 PHPS50_slab_rad.lammpstrj id type q x y z vx vy vz
dump_modify 1 sort id
#setup PKA
velocity select set 0.3388362 0.3388362 0.3388362 units box
fix 2 all nve
fix 3 all dt/reset 1 1.0E-3 1.0E-1 0.2 units box
restart 1000000 PHPS50_slab_rad.restart
run ${PROD} # 100ps
