Dear LAMMPS users,
I am a new user with LAMMPS. And I would like to use LAMMPS to calculate radial distribution function (RDF) and mean square displacement (MSD).
Unfortunately, the trajectories weren’t calculated in LAMMPS. I used VMD to observe and convert to the format of LAMMPS trajectories.
To calculate RDF and MSD, I think I have to:
- read data in trajectory file.
- run commands to calculate RDF and MSD.
However, I found that read_data command only reads initial coordinate. My trajectory includes several hundred frames.
How can I read data for this trajectory?
And is it possible to calculate RDF and MSD using LAMMPS if the trajectory weren’t calculated in LAMMPS?
Ha Linh |
Dear LAMMPS users,
Unfortunately, the trajectories weren't calculated in LAMMPS. I used VMD to
You cannot.
weren't calculated in LAMMPS?
No, it is not possible.
Axel
Ha Linh
Dear Ha Linh,
LAMMPS’s built-in tools for calculating RDF’s and MSD’s are only useful in the context of actually running a simulation.
You’d be much better off writing your own code, or using a tool like Pizza.py (which is also distributed alongside LAMMPS on the website) as a starting point. However, adding the overhead of LAMMPS to post-processing your existing data sounds like an ill-advised idea.
—AEI
Dear LAMMPS users,
since you have used VMD, why not use VMD for you analysis.
it *does* have a tool to compute radial distribution functions integrated
and using Tcl scripting in VMD to compute mean squared displacements
isn't that difficult either. i may even have a Tcl script fragment doing
this somewhere on my hard drive.
