i want the temperature of the system reduce for 100 times in a way that
ratio of two temperature of system in two consecutive mode be a constant
number. i mean: new temperature/old temperature = constant number(like
constant number=0.9). i want to see Phase transition.
in velocity command scale the velocity change in a way that temperature be
a fix amount. but i want temperature change like this for example: 10 , 1
, 0.1 , 0.01 ,... . i want it change multiplicative. do you have a
suggestion?
i don't understand the question. you are not making sense here.
untitled-[2] (3.82 KB)
you can do that easily using a variable, either using an index variable
with a list of those temperatures or using an equal style variable using
the ramp() function. also, you can use fix viscous to do the annealing.
this is not likely to happen the way you expect it due to finite size
effects causing a significant hysteresis.
