Temperature becomes really huge! Something wrong.
ReaxFF parameter file is format sensitive. Are you sure that you are using the right format? You may make mistake in the format while converting the pdf file to a text file.
It’s better to get the parameters file in the text format from the author if it’s not available online.
Sanjib
