Is it possible to use parallel technique to speed up the structure generation? As I understand maps search the ground states. Multithread can benefit this process.
Mingkai Li
Mingkai Li
This is actually implemented. If you do
make mpi
from the atat directory, it will create an mpi (so parallel) version of maps, mmaps and genstr.
