Hello everyone,
I’m thoroughly confused by how LAMMPS (27 May 2014) works, or rather refuses to. I’ve been successfully using create_atoms before, now I replaced it with read_dump reading a xyz file formatted as below:
52
Al4Cu9
1 7.69900 7.69900 7.69900
1 1.00700 7.69900 1.00700
1 1.00700 1.00700 7.69900
1 7.69900 1.00700 1.00700
2 3.42500 3.42500 3.42500
I.e. just like regular xyz dumps. The point in the input file where everything goes wrong:
region box block 0 $a 0 $b 0 $c units box
create_box 2 box
read_dump …/Al4Cu9.structure.xyz 0 x y z format xyz box no
ERROR: No box information in dump. You have to use ‘box no’ (…/read_dump.cpp:361)
I just used “box no”. The documentation on this error says “self explanatory”. I’m confused.
Is it not obvious that the doc page said that format must be the last keyword if used?
Ray
It’s probably a bug - can you post your input files?
Weird. I just looked at http://lammps.sandia.gov/doc/read_dump.html again, and I see “must be last keyword if used” (missed that before), but then the documentation goes on to mention a couple examples, like this one: “read_dump dump.xyz 5 x y z format xyz box no”. This was the original source of my confusion, then. When I did put format to the end of the line it worked. Thank you very much!
yes, Ray is right. The examples on the doc
page are not all valid. I just changed them.
Weird. I just looked at LAMMPS Molecular Dynamics Simulator again,
and I see "must be last keyword if used" (missed that before), but then the
the examples in the online documentation should be updated/corrected by
now. steve changed them yesterday.
